- Local time
- 3:39 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
So what are FI29 Customer Provision, LHS Footwell & FI30 Customer Provision, RHS Footwell then?
It maybe all part of the same thing.So what are FI29 Customer Provision, LHS Footwell & FI30 Customer Provision, RHS Footwell then?
That's going to be a long list!!INEOS Team will be delighted about all our collected questions on the fair next week.
Let‘s start a list.
They are the wire ends from the power outlets in the footwells. Each end has the bare wires which you need to connect to an accessry of your choice at one end and the battery at the other.
A continuity test with a multimeter would confirm.Are you sure, I thought there were already fused supplies identified for the footwell outlets?
Usually those little dash vents are a return air temp sensor for AC. If you look closely with a torch you might see a very small intake fan behind that draws air in across the sensor.It might be the mic for the passenger as part of the hands free phone feature of the IG .
Yes it would but until someone does making definitive statements such as "They are the wire ends from the power outlets in the footwells. Each end has the bare wires which you need to connect to an accessory of your choice at one end and the battery at the other.", and "99% certain" is just plain wrong.A continuity test with a multimeter would confirm.
