It looks awesome!
Brad,Got this fixed.
LRA fuel tank. New experience at the end of the year. About 12,000 miles on the LRA tank, very happy with it. But, above the muffler that was added, the rubber muffler hangar failed, it had become brittle, probably due to the heat. Simple fix, it is a BMW part, and Jeffrey Corwin at JC's British & 4x4 took care of it over lunch, and added a silicone heat sleeve over the hanger to protect it in the future.
View attachment 7915720View attachment 7915721
HI @parb. I’ve got the LRA Australia auxiliary petrol fuel tank. I already sat a bit low when fully loaded especially now with roof conversion also. I’ve added the OEM black mark springs and added airbagman airbags as when loaded I’ll be close to GVM .Brad,
Did you have to install stiffer springs with the extra weight from the gas tank?
Make sure to "season" the table. I used some cutting board/butcher block stuff I found on Amazon.I installed the gp factor table with cubby. I had the factory table but this is such an upgrade I had to get it. Thank you to the team at tinyrig, got it on the black Friday sale.
I have not added stiffer springs. A full gas tank is +150lbs, so well within the capability of stock setup.Brad,
or with FostersMake sure to "season" the table. I used some cutting board/butcher block stuff I found on Amazon.
Noooo. One must season the table to protect from a Foster's oil can ring or, God forbid, a lost drop of Australia's golden liquid national identity.or with Fosters
Do you know if Rhina Rack carries this rack in 3/4 size? How are you able to get that rack if they don't even offer it on their website?Just a little routine check and some minor work,
I added the rubber edging to the windscreen, then went around the roof rack tapping every section with a rubber mallet. I’ve had an occasional vibration I know is from the rack and after the mallet test I wound up torquing almost every nut securing the load surface. Not a lot of torque, but enough that the following rubber mallet check returned zero vibration.
A Robertson screw. A Canadian invention.Of course, this is not my week for installing things.
Tiny Rig ships square socket screws with their device holder that attaches just below the center air vents. Really nicely made, but, does everyone else have square socket drives? I sure as hell don't. Had to go swap out for screws that I could actually use. I mean, we have torx, hex, phillips...why reinvent the wheel with a totally new type of screw.
Those square head screws are rubbish especially when they are stainless steel. I used them for a deck and they keep tearing out. By far the best for me are torx head screws. As long as you use the right size bit. It’s easy on the smaller sizes to use the next size down bit as it feels ok but is slightly loose. I was repairing an out building last week and screws kept tearing out and sure enough I was using a tx15 instead of a tx20 bit. With right bit the stainless screws would snap before tearing out.A Robertson screw. A Canadian invention.
Even worse is the triangular head, a tri-wing or something like that.
I remember those from when I built a garage out in Quebec, remember them working better than philips screws, guess in part it depends on the quality of the metal.A Robertson screw. A Canadian invention.
Thanks, I appreciate learning about new tools, but, I feel as though that should have been clearly mentioned in the product description: "Hey we use a totally odd screw that you won't have the to tools to use. Good luck!"A Robertson screw. A Canadian invention.
Not to mention Phillips, Pozidrive and JIS which all look the same, but aren't.
it's difficult for me to trust a man with a beard and no moustacheIf you've ever seen an Amish-build shed, they almost exclusively made with square-drive screws.
