Thanks for offering! I got the wire harness so I think I'm good.
I was just a bit too tired to finish the wiring in the afternoon today. Going to finish it next weekend and also move the off-road lights I upgraded in the grille so both the ditch lights and the off-road lights are controlled by the same switch.
I run Baja 80 xl in the grill off one of the aux switches.
Going to keep them on the switch but trigger them with a relay that is activated by the headlight full beam.
I haven't fully finished the wiring but it's going to go up front and around the cooler..I ran my compressor wire that way and I'll just go along that run with these wires. All end up on the driver's side where I'll put it relay to control the lights.
Are you gonna run it to one of the ceiling switches?
I think I'll feed the power to the relays contactors from an overhead switch and then I'll use the headlight full beam to the relays control input to engage the relay. That way the auxillary lights only come on when the ceiling switch is active and the driver put on the high beam.
Nice! Take lots of pics please, that may be how I want to run my factory off-road light replacements when I finally take that plunge
I didn't feel the need nor want for the factory fender checkerplate.
But as an occasional place to put a cup, tool, greasy snags or whatever there, I've cut up vinyl BBQ mat from Bunnings.
The bonnet clamps it in place.
It can be stored anywhere.
Not sure if this was a good idea to attempt. Giving myself this week to complete at night after kids go to bed. Maybe I’ll just do the King shocks and leave the rest to Agile Offroad….
John’s install tips and video give all the hints for doing this, but as a 1 person job, maybe I’m being too optimistic on my garage floor…
Update:
Used the spring compressor tool that the Ineos portal suggested. Portal states nothing needs to be removed and compressor method can simply take spring out for replacement. Decided I got lucky with removing, but the upgraded Eibach may be more difficult to compress enough for my limited space on floor, and will slet pros do the springs, especially since I’m doing it solo. Shocks, though, are super simple. Fronts will get started tonight.
