Finally finished the GMRS install. I cut into the plastic and mounted adapter for my Midland 275 mic. When I'm not using the radio, the mic goes in my Tougher front seat pocket. When in use, I attached my mic to a set up I got from Amazon. The color match is almost spot on and cost less than 15 dollars.
This thread always confuses me - "what did you do with" vs. "what did you do to". Anyway couple projects over the past week or so.
First was, I got tired of the seatbelt coming across my neck, yeah, I'm somewhat vertically challenged. Anyway, saw this over on FB, so took a chance.
Front Seatbelt holder for 2015-2023 Ford Mustang
Easy install, sold as a pair. The holes are a bit wider than our headrests, but they fit with a little squeezing or you could dremel out one of the holes a bit. .
Next was to FINALLY install a LensunSolar panel on my hood. Took nearly a month for all the bits and pieces to arrive. I didn't go with their MPPT controller, but installed a CTEK 250SE using at GP Factor bracket. Still need to finalize the wiring, but got the panel mounted. Getting wires through the firewall was a B*#ch. Seems they taped the wires to the grommets on the engine side, so couldn't just "poke" the wires through.
Here are the specs of the solar panel - nothing crazy, but I don't have the roof space to put panels and the hood is wasted space anyway.
Finally, just for fun
My Leitner roof rack came in handy when I had to take (5) 33+” wheels/tires back from the tire shop. Three in back and two on the roof. I switched from 18’s with snow rated Yokohama AT4’s to 17’s with RT Yokohama X-AT’s.
View attachment 7904093View attachment 7904094View attachment 7904095View attachment 7904096
Who did your hood blackout (the spot under the now-installed solar panel)?
Looks as though your seat belt holder would fit better the other way up?
Did you do a clean and jerk weight lifting move with one in each hand to get them up there 🤔😂
The real challenge was me being 5’9”. Really nothing too difficult, mostly awkward. I weight train with some regularity so this wasn’t too bad. I only had to get the tire up against the rack and then it was just sliding them up into place.
