6:41 PM
I'm running out of Grenadier things to do. Anyway , after exhausting myself installing a S/S eyebolt for the trailer breakaway brake cable , I took my good lady for a scallop pie at the tiny cafe 1/2 way up our local mountain. Followed by a 3 hour circuit walk.
We have a 4 day hike on the west Irish coast and islands in May , so keeping up the fitness.
Eric
9:41 AM
Scotland
Fitted tow ball fixing bike carrier for the first time. Pleased it could take two bikes and allow me to keep spare wheel on the back.
I have an older "Pendle" 2 bike rack which has uprights to tie the bikes to as well as wheel restraint slots. Fortunately all these fitments are slide adjustable so I can move the bikes further back from catching the spare wheel.
Also please there is no conflict between opening the rear doors and the raised jockey wheel on my trailers.
AMD66
9:41 AM
I was pleased that I didn’t have to buy another carrier. I’ve lost the ability to carry three bikes, as the space is giffed to the wheel. When carrier is fitted, I can only open smaller rear door, but now I know, I’ll plan accordingly.
Your sliding solution seems to have been well designed so you can make it work.
Tom109
4:41 AM
I noticed a few oils spots where I park the Gren. I did a thorough below chassis inspection and found nothing. Strange as the drips were rearward, between the t-case rear output and the rear diff. I was rightly perplexed. Then I remembered - I parked the RRC in that spot for a few days last week.
Global Grenadier 0076
4:41 AM
There's a new kid in town so the RRC is marking its territory.
beg
9:41 AM
Scotland
I also did some cleaning today, because of that summit, but I didn't remove the carpets.
:p
I also removed the rear left trim panel (second time, first time was here), because I have some water infiltration: I discovered quite some water below the hydraulic jack, and I want to search myself the cause, otherwise my dealer will keep my car and give me a Mercedes replacement car, and I don't like it.
See the picture:
If it doesn't rain too much I will begin dismounting the underseat right side trim panel (see the fantastic explanation of @DCPU here), because I did buy an ARB CKMA12 compressor and want to install it.
Are those drain plugs Jean and did you find the cause of water ingress ?
OGrid
6:41 PM
Today, and for the next week, I’m camping remote next to Swampy Plains Creek in one of the Australian high-country alpine national parks.
Two creek crossings at night (@23:30) to get to this spot. Vehicle ate them up.
I converted my Starlink to a 12v input last week and currently running it off the vehicle’s secondary battery. Working very well. Starlink natively runs 48v, so the 12v setup that does a 48v step-up is vastly more efficient than using an inverter. Can’t claim any credit, as followed the trailblazers in the US RV scene who cracked that nut a while back.
Jean Mercier
GG#920
10:41 AM
Sint-Martens-Latem, Belgium
No, it are not drain plugs, like the ones you can remove.
And my workshop thinks the water came from the right rear ventilation grids, but I have my doubt, therefore I am still monitoring this.
It is or was anyway a very slow water infiltration.
beg
9:41 AM
Scotland
Mine is in for service and I've asked them to investigate the issue so hopefully will get some feedback if not its dismantle time .
TheDocAUS
6:41 PM
Eromanga
FLAG POLE MOUNTED
Today I mounted the Bushranger Safety Flag onto the roof rack. You can vary the flags height, using 1, 2 or 3 fibreglass poles.
I used a Razed antenna mounting bracket and attached the bottom of the flag pole onto the bracket (these 2 images are from the Razed website).
The nuts were torqued to 7Nm, and I used Nord-Lock washers, instead of the supplied split washers, as Nord-Lock washers will not come loose due to corrugations. I placed the bracket in a corner near the solar panel to minimise its drag profile. Final fit looks like this:
Tom109
4:41 AM
FLAG POLE MOUNTED
I love the Razed stuff. I contacted them but they only ship within Australia.
TheDocAUS
6:41 PM
Eromanga
I really like their gear, but quality means expensive freight, esp overseas. I had their grab handle and I realised I could use it to get into the car. So I installed it over the driver's door.
Razed should think about licensing overseas fabricators. Or ta;k Razed into using Sendle for overseas freight.
DaBull
1:41 AM
California
TheDocAUS
6:41 PM
Eromanga
globalgregors
6:41 PM
Sydney, Australia
