Fabulous job with the drawer but those pictures are amazing. I zoomed right in and still stayed pretty clear. Please post more in the 'Random picture' thread with details of what is in the picture. 🙏
Just stay away from the monthly competition, which does require your Grenadier to be in view or part of, as it's obviously cheating 🤣
Thank you!
Roger that, but no promises! I'm taking a trip up to Colorado / Utah next week and planning on having one or two shots with the Grenny :ROFLMAO:
  • Well done
Reactions: CRH
Winters back on - got caught out with a bit of snow this week but it has reinforced my opinion the BFG AT are absolutely fine in fresh snow with lots of feel and good bite but are pretty unpleasant on compacted snow and ice. Dropping the pressures certainly helps, down to 30psi and they are much better but nowhere near as good as dedicated winter tyres.
I do wish there was an MT pattern tyre with lots of sipes and a winter compound. I’d never buy anything else.
A track I use 2 or 3 times a week is muddy and deeply rutted and the AT’s cope fine with it but I rather suspect that when the snow is gone these winters will be useless on it if the ground is wet.
Always the annual dilemma - I need my muds more in the autumn/winter but then occasionally I need one with a softer compound and lots of sipes - unfort too much of a compromise, one or t'other so I stick with muds and only swap over to the AT's if heading to snow sure places, agree not great on the hard stuff or ice but better than my muds. Will probably look for a dedicated winter, nokian etc when the AT's have had their day.
That’s interesting 👍
We have an old Hilux on Toyo MT’s and I swear it’s better on ice and packed snow than the Ineos on AT’s 😅
In fairness, I used Grabber AT2’s year-round on our old 90TD5 for years, all year round, and they were fine. Maybe it’s just the BFG’s I don’t get on with.
I wonder if their (BFG) AT K03's are any better in the packed stuff....you'd hope there would be an improvement all round but again maybe at the improvement of one element comes at the expense of another.
P.s. when you say 'old' Hilux - what era are we taling?
Ahh not that old, 2010. Mk 7 maybe? Not sure 😅
This swapping tyres with the seasons is such a foreign concept to us Aussies.
The closest I get is wanting to put on a set of mud tyres when I head outback, but touch wood so far I’ve made do with agressive AT’s.
Trip to Thredbo this winter?
The Toyo seems to be the best siped-MT available. I think I’m still going to skip it in favor of the 35” Mickey Thompson Baja. We don’t see a lot of local snow but a few trips every Winter do.
A few more minor changes - I had the Grenadier USA center console and I liked the fact it was metal but the oversized cupholder was 3D printed with a glossy surface that showed print lines (made it look cheap) and so I decided to go back to the original (sorta). I found a replacement oversized cupholder that only replaced the original cup holder section of the original center console and went with that. I liked the small silver rails from the Grenadier USA console and so I installed those (drilled holes in the original center unit) and then covered the center unit and the front unit (where the shifter is located) with a gun metal gray wrap so everything matched. Finally, I painted the center console dial black to match the Grenadier USA transfer case shifter knob I had previously installed (which now matches the other knobs in the Grenadier). I like how it all turned out and now everything looks OEM. That's what I did today!
Very nice job! I’d like to get a GrenadierUSA center console but like you the printed cup holder does look a bit cheap which is especially galling considering the quality you are getting with the machined console and what you are paying for it. I wish they made a version of the aluminum console which would work with the OEM cup holders but it might not be possible due to how the OEM unit is made?
Grenadier USA doesn't make any tabs or slots on the bottom of their console for the cupholder to "snap" into. The unit that I got and installed in the image above does have snaps just like the OEM console, but both are plastic. I suspect the metal console is harder to work with in terms of adding slots/tabs on the underside. The Grenadier USA cup holder just sits in the dash and is held in place by the screws that go through the console from the top - not a great solution and one of the corners in the Grenadier USA cup holder cracked when I was installing it because the plastic at that point is very, very thin. It's unfortunate because as I said in my post, I really liked the metal console and thought it was more rugged than the OEM plastic.
Ventured up to Moffit Tunnel above Boulder Colorado with Darling the dog to check out the ice climbing conditions. Still early season even at 9,500ft in the Rockies! Need a good deep freeze and some precipitation!
Just fitted the Falken Wildpeak AT4s to the beast. A Falken 265/70/R17 in the AT4s looks like I went to a 275 or maybe even a 285.
Still plenty of tread on the "old" KO2's. Three of which are being moved across to my Stockman Pod trailer. The fourth was fitted to a spare rim I bought for the IG, as a second spare.
I do not see the point of buying new tyres for the trailer when there is plenty of tread still on the KO2s. So I put some milasge on the KO2s and moved them across.
It came down to KO3s, AT4s and Cooper ST Maxx (which I used for many years on the Patrol without a single puncture). Coopers was knocked out first, then the KO3s.
The steering is lighter but that may just be the new tyres with a slick surface. I go for a longer drive this afternoon after I correct the tyre pressures.
EDIT: torquing of wheel nuts checked. Tyre air pressures fixed. I suspect the tyre shops gauge needs calibration.
SEALED SNORKEL FITTED
GrenX finished work on Wally today. DIff breathers installed, rear airbags as well and most important a sealed snorkel.
Some induction noise is obvious now that the system is sealed. A lot less than the induction noise on the GrenX snorkel on Rohan's car (my loaner car and a different model). Still waiting on the sealed diesel airbox replacement, so the snorkel is currently plumbed into the OEM airbox. That will be a 15 minute job.
A sock/filter is coming for the snorkel, GrenX is working with Unifilter on that. It will be added between the current grille and the snorkel head. I will be getting one. You can see the 4 screws in the picture below.
The induction noise is there because the air is being drawn just from the snorkel opening, whereas the OEM snorkel allowed air to be sucked from a few locations, as it was not sealed.
I drive back home tomorrow morning. A long day on the road. I was going to buy fuel and remembered I had it in the rear fuel tanks. So one container went into the car.
@Adam-Oz should have an update coming, we left together on Monday and arrived back at GrenX within 60 seconds of each other today.
Great product. I’m currently waiting for mine. Concerning the Unifilter pod filter used within the sealed airbox - Do you have a part number? I’d like to pick up a spare since these are somewhat difficult to come by in my neck of the woods. I’m also curious about the airbox drain - Is this a plug or a ball valve?
My car is diesel and the diesel airbox in being made now, it will be available before Christmas. My sealed snorkel is plumbed into the OEM airbox and is not yet watertight inside the engine bay.
I have asked for a second filter, but I do not know the part number. There has been two filters used on the petrol version Rohan told me about a week ago. You will need to get the Part number from GrenX (Rohan).
Thanks for the information. I’ve sent an email to Rohan asking for the relevant part numbers. I’ll post those once I get a response.
What have I done to my Grenadier today - Hmm… Quite a bit actually:
Image of the 300W solar array captured during the install process:
More ( snorkel, sealed airbox, diff breathers, REDARC electronic brake controller plus some “minor” items… ) to come as well.
