Water on Tap
Oz4WDriva
1:15 PM
Melbourne, Australia
Having been used to water readily available on the rear of several Land Rover Discoveries I was hard pressed not to do the same on the Grennie. Using a 22 litre Proquip plastic jerry can as the basis I set about making it fit. I utilised the 6 OEM ladder mounts and chose a partial welding and bolting arrangement to provide ease of assembly and disassembly if required.
The tap is located toward the car centre when the door is closed so that it is very accessible when open. It still provides access for quick hand rinse or whatever when the door is closed. It is a lever action tap, not a twist tap that comes with the jerry can. I have found the lever taps to be more easily used and reliable over time.
The rack also provides a quick mount for an LED camp light which can rotate through 360 degrees to provide light in any direction. I retained the ladder concept for build strength and it is there if needed.
Weights are: frame 10 kg, jerry can 1.5 kg and water 22 kg gives a total of 33.5 kg. This will be a dynamic load on the rear door so I will keep an eye on it, particularly on the corrugated roads in outback Australia.
Nice job. I've been looking at something similar. The LeTech ladder is $1950 AUD and I just saw that GrenX have a ladder now as well, at $1650 AUD. Your solution looks more economical though I lack the tools and skills required at the moment.
I'd be curious to see how it goes over corrugated roads over the long term indeed. Keep us posted!
I went with the vaast 18L tank, X-spec mount from expedition had with Joolca gravity fed tap…
I bought the LeTech ladder and it fits a Wavian fuel jerry can very nicely. I have a couple of wavian water containers and was hoping to use one of them. They are nice because they have a tap at the bottom and you can leave can in place and fill dog water, water bottles ect. Problem is that apparently they are thicker than the fuel jerry can and would rub on the paint, which is a no go. I saw some people have the front runner water can which apparently fits on the LeTech ladder but I noticed that the bottom spout is blocked by the base of the LeTech as it is inset. Anyone have a good water container solution for the LeTech? Wavian makes a stainless steel one that is very pricy and doesn't have a bottom spout but maybe that fits?
Ah that's interesting. Where I live it's not legal to have fuel jerry's mounted on the outside of the vehicle, my use case is just to carry some extra water (already have an internal tank for 60L). In Australia the ProQuip 22L (https://www.proquip.com.au/plastic-fuel-water-cans/22l-heavy-duty/) are most common so I'm looking for a solution that suits this size. This jerry also has a bottom spout, which I agree you definitely want.
Some other options over at the list as well.
TANKS – WATER AND FUEL
  2. DUNN & WATSON water tanks here;
  3. The generic Jerry can used for fuel and water is commonly available. They can be carried inside the car (water), on the roof rack or molle panels on the car;
  4. PAK Offroad has a water tank for the footwells in the rear, or a new roof rack mount with recovery tracks called the RACKTANK (unknown if the TUBTANK or Wheel arch tank can fit into the QM tub); (thanks to @globalgregors and @Rok_Dr);
  5. VAAST has range of water tanks that can be mounted on a roof rack, inside the car or on Molle Panels;
  6. ONTAP Portable Shower, Original here , Black Limited Edition here;
  7. BOAB Offroad has fuel and water tanks, look here; and
  8. ORS can fit stainless steel water tanks (including for the Grenadier, I have one installed), look here.
I see you are in Australia. How come ronnie Dahl had multiple jerries mounted to the outside of his grenny including on the ladder in his series of review videos?
Roads rules prohibit fuel on front and rear, but not sides. So he should have water on rear ladder and fuel on sides. He could also put a couple of the roofrack.
Plus Ronny had a diesel model, which is less of a risk verse petrol for accidental ignition.
Great, thanks.
Have you seen anyone install this ladder? https://grenx.com.au/products/rear-ladder-with-jerry-can-holder-price
I wonder if it fits a ProQuip 22L jerry (have contacted them to find out). I've got an OnTap that I'd love to fit in there.
Did you get this from a US distributor? I like this option.
No I ordered from Adam at expedition HQ and they shipped to me. Also got a second x-frame and pantry for the other side. Very easy to do business with. Shipping was DHL and they provided updates at each step of the way.
Nice job. I've been looking at something similar. The LeTech ladder is $1950 AUD and I just saw that GrenX have a ladder now as well, at $1650 AUD. Your soluti noething came loose orf ailed on and Oon looks more economical though I lack the tools and skills required at the moment.
G'day Hugo
Just finished a 5,000 k trip to outback South Australia which included several notorious corrugated roads, including the Borefield Rd and Oodnadatta Track. I'm happy to say nothing came loose or failed on the water jerry can modification,
The factory accessory table on the inside of the rear door did come loose though! It was most likely as a result of a wind deflector for a camp stove that was stored in it. It is not there any more and I suggest that the fold up table is okay unless loaded up with 'stuff'.
Cheers Pete
Is that the vaast surface bracket or something else. I emailed Mat at Vaast to see when the blue will be back in stock and to get a rate quote for shipping.
I got the brackets from expedition HQ - they fit their side panels.
@HugoB - did you ever look further into whether the OnTap fits the LeTech ladder? I'm considering that exact setup atm and am wondering what the fit is like.
I have seen images from XHQ with the Ontap fitted to the LeTech Ladder.
You can see it right at the beginning of this video, pretty sure Warwick discussed it later. EDIT see at 2:37 and following.
View: https://youtu.be/0KNv17uFR2Q
I reached out to suppliers and non could give me a straight answer. But it seems like the question is answered by the video below!
I like the look and functionatlity of this ladder but the cost.. just to add a 20L jerry. You could probably get something custom fabbed up for way less, to attach to the ladder. Or even just this. I'm not sure yet, let me know what you end up doing :)
There are DIY posts on this forum showing a Jerry can mounted on the existing rear ladder. I will link it if I can find it.
