UK Spec lower NS/OS lower radiator strengthening
ECrider
12:59 PM
Was at the dealer today to get a bit of work done. Spotted a Gren there with it's plastic fron bumper off giving a much clearer view of the lower rads on either side of the vehicle.
As we know the UK (euro) spec rads are not supported by means of the OEM strut and a couple of forum members have suffered one of them coming loose out of the top bracket when driving on corrugated roads in Africa.
The problem is the vertical vibrations meaning that the rads can jump out of their rubber grommeted pins of the top retaining bracket.
@Logsplitter managed to jury rig his until got to a dealer and had the lower struts pinched from a donor ROW spec vehicle. His struts appear to have been attached to the lower part of the large steel front member/bumper which the UK plastic bumper attached to. A bolt or nut was welded on. Whereas the ROW models have a different lower bracket with a fixing that the strut bolts to, perhaps a captive nut.
So for those that are interested the solution is to try and get both the struts and the lower brackets from a UK dealer, whether this is possible I don't know. I am still awaiting for a reply from Adventure Automotive, Oxford. It is not known whether the lower brackets of the rads will fit on to our plastic bumper models, I am willing to give it a whirl. If not then we weld a fixing on a la Logsplitter's mod.
There was a very valuable post from @CountyV8 with CAD screenshot of the Ineos parts and prices on the 'Stuck In Namibia' post. Will try and attach here.
Note that the rads left and right differ in size and the top brackets are different, whether this is the same for the lower brackets and/or strut I'm not certain.
I for one would like this mod asap.
Very informative photos @ECrider 👍🏼. I’ve used your images and drawn lines in red where I wrapped the fence wire around to clamp the top and bottom rad brackets together which lasted for thousands of kilometres. Note that I could not work out how to take the plastic outer bumper off so may have done things differently had I been able to work that out and so see exactly how the rad brackets were fitted.
The photos with green marks around is where I would consider putting a stainless steel cable tie around or made up bracket to encapsulate the rad in its brackets. Should ever have an issue again.
Very informative photos @ECrider 👍🏼. I’ve used your images and drawn lines in red where I wrapped the fence wire around to clamp the top and bottom rad brackets together which lasted for thousands of kilometres. Note that I could not work out how to take the plastic outer bumper off so may have done things differently had I been able to work that out and so see exactly how the rad brackets were fitted. View attachment 7890880View attachment 7890881View attachment 7890882View attachment 7890883View attachment 7890884
Thanks for that, I was wondering how you rigged up the field repair 👍. Good for is to know.
After being lost in the post for 6 weeks I have finally received the struts and bolts from Harwoods. Though I ordered two they are only for the RH side so expect I'll have a spare. Couldn't order the bracket either so may have to bodge it. Will report back if find a solution.
I've been liaising with Black Sheep who earlier this year supplied me with the ARB Compressor Mount and Side Steps.
They now offer what looks to be an excellent solution for LHS and RHS - hoping to get my hands on them next week!
they seem really well made but I can't find them in their online shop
are the supports all the same between LHD, RHD, diesel and petrol?
Reactions: CRH
I couldn't find them either, a link would help, please
My local garage just took the bumpers off and fitted the Black Sheep radiator strengthening brackets. They were super impressed and the new brackets fitted really easily - just requiring a longer bolt to replace one of the originals. Very happy with everything and would highly recommend - if only for the peace of mind before taking on a long journey. Off to Iceland in just over 3 weeks. Can't wait.
How long are you staying in Iceland?
Reactions: CRH
Did you pirchase direct from Black Sheep
Which local garage did you use ? Tx
It was n't an Ineos Dealer (my local one has closed shop) but The Village Garage in Bishops Waltham. They were great. Kept the car for five days and tinkered with it when they had time, but I'm very local to them so not an issue. They also checked the pipes etc, wax oiled parts of the suspension that had some surface rust and upgraded all three wiper blades.
Three weeks in Iceland - travelling there via France, Netherlands, Germany Denmark and Faroe islands. Should be great
Have fun on your journey. When you come back, I will take your place and continue the journey.
Yes I did. Circa 300 CHF plus approx £60 VAT and import charges
I can't find them on their website, I've looked a couple of times, any chance you could send me a link, i am pretty incompetent with this stuff.
Sounds amazing, I am guessing you WILL BE posting plenty of pics on here for us to drool over.
You are doing my dream trip for when I retire.
