Tyres/tires: Falken Wildpeaks AT4 review
TheDocAUS
11:25 PM
Eromanga
BACKGROUND
Over 30,000km driven in the IG with the BF Goodridge KO2's (KO2) tyres fitted.
Over 150,000 kms with Coopers ST Maxx tyres (ST Maxx) on the Nissan Patrol.
CONTENDERS at TYRE SIZE 265/70/R17
The tyres I considered to replace the KO2's were:
  • BF Goodridge KO3's (KO3) - the leading contender, thanks to @globalgregors;
  • Coopers ST Maxx - my long-term trusted AT tyre; and
  • Falken Wildpeak AT4's (AT4) - the new boy on the block, suggested by the Tyre Shop.
The ST Maxx was the first tyre dropped, as it was a lot more expensive than the other two brands, even on special. The ST Maxx’s real strength was a 3 ply sidewall, but now the KO3's and AT4's also have a 3 ply sidewall. I never got a flat or sidewall damage using ST Maxx’s, so I want a 3 ply sidewall.
The current KO2's still had plenty of tread, but I needed three tyres for my Stockman Extreme Offroada trailer and a second spare for the IG. I will not buy new tyres for the trailer, so I did over 30,000km in the IG first. There is still plenty of KO2 tread left for a spare and trailer use.
As an aside, the IG is much kinder on tyres than the old Nissan Patrol, which was brutal. The KO2's were still in really good shape with even wear across all 4 tyres (rotated every 10,000km).
This meant new tyres for the IG.
I looked at a lot of videos and reviews between the KO3's and AT4's. It was a hard decision but I went the AT4's because they had a stronger carcass and they were also AUD45 less each tyre. A saving of AUD180 overall. The AT4's seemed to give me everything I valued in the ST Maxx, but for less. I only had to give up the white lettering which the KO2, KO3 and ST Maxx all have.
Watching a video comparison of the KO3 and AT4 at a larger tyre size the AT4 was more robust and heavier than the KO3. As I was buying the tyres to head Outback and The Kimberley I went with the stronger carcass. Someone not going remote may prefer the lighter KO3.
The AT4 carcass reminds me a lot of the Cooper ST Maxx carcass. Less so the KO3, even with the 3 ply sidewall.
INITIAL OBSERVATIONS
I ran the original KO2's at 35 PSI cold, after 5 minutes use they would be around 40 PSI. The AT4's are set at 35 PSI cold. A Cooper's rep previously told me the ST Maxx was fine at 35 PSI rather than 40 PSI cold, due to the strength of the carcass.
I have only done local travel, dry roads and nothing above 70km on the AT4's so far. My initial observations verse the KO2's are:
  1. better grip;
  2. no rubbing with a small Eibach springs lift (a Ranger Raptor, at the tyre shop, had to go down 2 tyre sizes when fitting the AT4's to avoid tyre rubbing);
  3. the new tyres feel sure footed and have good dry road traction and braking;
  4. you get more feedback from the road surface, which may be the firmer side walls and tread blocks;
  5. improved steering response, turning seems sharper and more responsive. Again, it may be the firmer side walls and tread blocks;
  6. car definitely turning tight roundabouts better;
  7. easier return to centre with OEM damperer fitted;
  8. I can no longer feel the treads and sidewall squirm a little like on the KO2's (especially at very low speeds on hard surfaces). This is to be expected as the AT4's, as well as the KO3's and the ST Maxx's, all have 3 ply sidewalls;
  9. driving on smooth roads feels good;
  10. the ride is harsher over rough roads. This was expected as the ST Maxx's did the same. It may improve after the new tyres get some kilometers into them and settle in;
  11. there was one big unexpected difference, tyre temperatures. After 40 minutes of driving up to 60 or 70kph, the PSI only went up by 2 PSI, not 5 PSI like the KO2's after just 5 minutes. This also meant lower rim temperatures. This seems to be a benefit of the AT4's stronger carcass, thicker tread, heavier weight and larger size, compared to the KO2; and
  12. for snow/ice/sand/moderate rocks performance look here. The places I go are much more likely to give extreme heat, than extreme cold.
No highway, wet road or offroad driving yet, but that is something I will look at closely, as well as heat soaking into the carcass on longer drives.
Lower tyre temps will be a bonus, but I now need to consider whether I increase the PSI to 37 or 38 PSI cold.
A thank you to the Tyre Shop for suggesting the Falken AT4's.
My initial view is the AT4 is a better all round tyre than the KO2s. Still early days.
HIGHWAY USE
My initial observations have been confirmed by highway use. In summary:
  1. better grip than the KO2s;
  2. the AT4s feel sure footed and have good dry road traction and braking;
  3. less road noise than the KO2s, up to 110kph;
  4. the AT4s definitely run cooler than the KO2s, even at high speeds. See more detailed comments above in point 11;
  5. I am surprised how long it takes to get heat into the tyres even with ambient air temperatures high, like 35C to 40C;
  6. I think the AT4s will ultimately build up the heat, but it will take longer. I need a really long drive or lots of corrugations to confirm that; and
  7. the KO2's are good tyres, but the AT4s are better in a number of areas, making the AT4s a great upgrade. It is the combination of incremental improvements across the board that make the AT4s better.
The AT4s behave and feel more like the Cooper ST Maxx tyre, than the Bridgestone KO2s (but without the ST Maxx's premium price tag).
WET ROAD USE
The AT4s perform better than the KO2s in the wet. Not much high speed driving on wet roads as yet, mostly local roads. Noticeable improvement over the KO2s.
OFFROAD USE
Limited offroad use so far.
Long term review to come.
I put > 15k miles on my 255/80R17 AT4Ws. Far better than factory Bridgestones, so far excellent in snow/ice/sand/moderate rocks. Very little mud (it is rare in our neck of the woods). Excellent wear, suggesting the useful lifetime near 45-50k miles.
I would also say they are far "rounder" than the last sets of BFG A/T and M/T I had.
The improvements of the AT4s range from minimal to modest. Lower tyre temps is the big difference, but the other improvements all add up to an improved driver experience.
Easier return to centre is another plus, with the OEM damperer fitted.
The improvements of the AT4s range for minimal to modest. Lower tyre temps is the big difference, but the other improvements all add up to an improved driver experience.
Have you tried them aired down yet. I found the BFG’s on the Grenadier overheat when aired down .
No, but the KO2 are much hotter, without lower the tyre pressure than the AT4s. Lower temps should mean less damage to the tyre over its life - I am keen to see what high speed temps are like. I noted this above, see red highlighting:
Pretty sure the KO3's and AT4's will be better than the KO2's aired down. Both newer tyres have 3 ply sidewalls and a more robust carcass. The AT4 being heavier and more robust than the KO3's.
HIGHWAY DRIVING
I did some high speed driving today, up to 110 KPH, on a 1.5 hour return trip. Dry roads.
The Falken AT4's definitely run cooler than the KO2's, even at speed. Even after 45 minutes of high speed driving, the rear tyre temps never went above 38 PSI, the fronts around 36 to 37 PSI. The KO2's would have been at around 41 PSI, maybe 42 PSI.
The car was a little heavier coming back, and the on-road performance was better than the trip over.
The performance so far, has been a nice upgrade from the KO2's.
HIGHWAY DRIVING
The car was a little heavier coming back, and the on road performance was better than the trip over.
The ultimate test on increasing temperature and pressure is going to be high speed towing. That usually adds another 2 psi and a few more degrees temperature on mine.
I have a few other tests first ! But you are correct. However, my van is lighter than the small townships many people tow around Australia.
The car is definitely turning tight roundabouts better, with the AT4s.
I noticed this early on, but it has become crystal clear it is a big improvement over the KO2's.
Looking at doing similar.. updating I.G. with the Falken LT265/70R17 123S AT4W. My 3t van needs new tyres and the I.G. KO2s will fit. With the KO2s on the I.G. and towing the van in the wet on sealed roads I've experienced understeer going into corners - somewhat unsettling shall we say. Never had this before with other tow vehicles/tyres and same van. Have learnt to slow down somewhat with lower pressures in the front to increase tyre footprint. So a tire change on the I.G. will be most welcome. Can I ask if you have had any more experience with the Falkens towing on wet roads?
Only driving on wet roads, not while towing. The AT4s handled better than the KO2s in the wet, noticeable so.
My next towing trip with the new airbags, tyres, steering damperer and suspension is early March. The new suspension is needed for the Kimberley trip later in the year, if all goes well.
Do you have airbags fitted to your car? When I was last towing (without airbags) the back sagged a bit and I could notice lighter steering at the front (and less grip). I now have airbags to address that. Damperer and suspension is coming.
I have the 3800 gvm upgrade from SLRV that replaced all 4 springs however did experience perhaps around 35mm of sag with about 280kg on the ball and drawers, fridge in the back. Spoke with Ric at SLRV and then upgraded the rear spring to a further heavy duty Eibach and now I guess 25mm sag. Have experienced a few issues with air bag helpers at worst possible times outback and now prefer to set up vehicles without relying on those. (Having said that I have air springs in my van but they're a different kettle of fish so to speak) The Ineos is not too stiff in the rear with the heavy duty springs and still have plenty of travel but I always have a bit of weight in the back even if not towing. Very happy with the suspension set up and vehicle is superb, not so the KO2s in the wet...
COUNTRY TRIP
I got away for a 2-day trip into the country to test the new AT4 tyres. I travelled around 700km with speeds up to 110kph, but mostly 90 to 100kph.
Day 1 was around 27C (ambient air temp) and Day 2 around 18C (ambient air temp), cool for summer. I drove on freeways, regional roads with no proper base, but a layer of bitumen over the top and roads made up mainly of patches. So a variety of surfaces. Minimal offload use and only a few corrugations.
Grip was good, including during the wet. The stand out was the thermal control of the Falken AT4 tyres. Cold tyre pressure only went up 2 to 3 PSI and the tyre temps and PSI were much lower than the BF Goodridge KO2s. Almost no heat build up, even after hours of driving - so impressive thermal control.
The PSI variations between both days was non-existent. AT4's have superior thermal control compared to the KO2s. Lower PSI increases and overall tyre temp changes.
The trip confirms my earlier feedback.
The main remaining test is corrugations, which I will test later this year, if I go to the Kimberley. Plus an upcoming trip towing the van on the new tyres.
The combination of the new tyres and the new throttle controller made for a pleasant journey. AU spec diesel. These smaller changes and improvements are starting to add up.
COUNTRY TRIP
Day 1 was around 27C and Day 2 around 18C, cool for summer. I drove on freeways, regional roads with no proper base, but a layer of bitumen over the top and roads made up mainly of patches. So a variety of surfaces. Minimal offload use and only a few corrugations.
Grip was good, including during the wet. The stand out was the thermal control of the Falken AT4 tyres. Tyre pressure only went up 2 to 3 PSI and the tyre temps were much lower than the BF Goodridge KO2s. Almost no heat build up, even after hours of driving - so impressive thermal control.
The only remaining test is corrugations, which I will test later this year. Plus an upcoming trip towing the van on the new tyres.
That's surprisingly low temp rise.
Apples and oranges but my KM3's easily rise 6-8 degrees.
I monitored PSI more closely, but temps did not move that much either. Based on previous drives, tyre temps were fairly stable as well. Temps did not move that much as it drives PSI increases and the heat saturation effect, both of which were minimal.
The other temps were ambient air temps. I have amended my first post to make that clear. Sorry for any confusion.
At Heasmans in Sydney yesterday, a passing comment was made on how good the AT4s on my INEOS were and I agreed.
So the Heasman sales guy, their wheel alignment expert and I were in agreement. The Falken AT3's and now the AT4's are building a great reputation.
