Tyre inflator advice
ECrider
7:23 PM
Expecting a small report now, with copious photos, and a special section on it's uses around a Grenadier...
being used on level 4 presently to blow away the Grenadier blues (sick of waiting syndrome)
8:23 PM
Well used mine it to check the tyre pressure in the spare as there's not clearance to get my normal gauge in there - and bumped the pressure up to 49psi as per handbook recommendation. Worked a treat:
Letters inside == valves inside? :oops:
Never thought about it. So the tires haven't been re-mounted on the rims to have the letters inside, but the rims just got turned? Is that possible?
I thought that only one side would fit properly for the bolts. 🤔
4:23 AM
BFG lettering is outside from factory.
Spare wheel is mounted "backwards" to allow for the storage box,
Fab
8:23 PM
Dinslaken Germany
Never thought about it. So the tires haven't been re-mounted on the rims for letters inside, but the rims just got turned? Is that possible?
