General Two attempts of tuning the chip did not work!
Sauerländer
12:26 AM
Selm/Germany
I don't want to start a discussion about sense or not, but in my world, after owning several Defender and Discovery TDI 300 and Td5 i'm convinced that Chip tuning is ok, if You take care of the possible disadvantages.
So was my decision, to get a Tuning box for my Grenadier Diesel. Looks much easier than to get a new file on the ECU with a Nanocom...
The first one, from Speedbuster in Germany, used to throw engine lights. I could erase them, but after I started the engine again the light came back. The difference in power was overwhelming.
So I took it out and sent it back.
Then I ordered a TDI Tuning box. I pluged it in, like suggested, but not LED on the box was working. The engine started but I did not even test drive it, because it was not like the manual told me.
I checked the wiring, but to me it looked great. No engine light came up.
I took the harness out again and now I'm waiting for an answere from TDI Tuning and their recommendations.
Reagards Horst
I am sorry to hear you have had this problem Horst. My experience is only with TDI on on the B58 (petrol) engine.
After letting the engine control systems go to sleep (very important) I installed the TDI Tuner with the app and it fired up flawlessly and works perfectly. I installed mine for better fuel economy and it delivers as promised with a 20% increase in fuel economy on setting #2.
My experience with the people at TDI is they stand behind their product.
Reagards Horst
Make sure the plugs are around the correct way. I have had this before. TDI were very prompt in getting back to me with solutions and after I gave them some feedback on the tune and updated it via the app it's worked flawlessly
I double checked it and I think, it is not possible to stick the connector for the fuel sensor on the boost sensor.
I'm lookiing forward for their response.
Regards Horst
same color different power plant!
Regards Horst
It is possible, I've done it myself 🙄
Installing my TDI tuner was very easy and required no tool. I had a small screwdriver handy to help with removing the plugs but did not need it. I did use a diagonal trimmer to shorten the zip ties used to secure the tuner and wire looms under the hood.
Two days gone now, when I sent my inquiry to the companie TDI Tuning and I did not an answer yet!
:rolleyes:I'm a little surprised!
I received an answer yesterday.
From the explanation of a technician from TDI tuning, there might be a small chance that I have put the connectors together in the wrong direction.
Not the connectors to the sensors, but to the harness.
If so, I probable will be happy and I will apologize for my stupidity!:cool:
Regards Sauerländer
This afterrnoon I had time to reinstall the harness of the tuning box and to keep an eye on the exact direction of the connectors before connecting the box!
Like MrsMike said t is easy to put them together upside down! Obviously so did I!
The box is working fine now, no issues so far!
So I apologize for believing that I mounted the box right in the first try and believing the box is not working!
Regards Sauerländer
As I tried to install the harness that was sent from the TDI Tuning, I had problems that the plug to the Fuel Sensor although matched in the connection but the lock that keeps the plug in place did not lock.
I could pull the plug off without pulling a little grey hock and pressing it down.
I could not believe it and tried harder to get the lock locking. In the end the lock broke and I had to fix the plug it with cable ties.
I sent an Email to TDI tuning and they sent me 2 new plugs! Very friendly, thanks for that.
Today I try to change the broken plug to a new one.
What I discovered, there is a stamp on the plugs that TDI sent to me VAG part.
Ok, I though f**k, they all use the same plugs.
But, the plug did not lock, like the original at the harness also did not! No improvment!
Then, I sent an Email to TDI Tuning.
The recommend to make a video of the connecting process to check what is wrong.
Before I called a friend, owner of a garage here and asked him if a VAG plug would match to a BMW sensor. He said, "NO WAY"!
TDI Tuning told me, they only use BMW parts!
So, how might they explain, that the plugs they sent to me are stamped VAG?
So far it is starting to annoye me!
TDI Tuning wants me to make a Video, trying to connect a VAG plug to a BMW sensor to find out what I'm doing wrong?
By now I'm not working as a mechanical engineer, but when I went to the University studiing ME, I did not have a seat at the window....
To end this annoing story, I will order the right plug at BMW to get a connection without cable ties if TDI tuning is not able to send the right plugs.
For all the users off a TDI box, I recommend to check, if the plugs are locked on the sensors and that they do not jump of on occassion!
Regards Sauerländer
