- Local time
- 12:33 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
Thank you.Obviously bottom one was the original![]()
Hi, My Fieldmaster is in to have the steps fitted but I was told there is a recall on the transfer box and mine will be replaced at the same time as fitting the steps.I collected my Trialmaster from Grange in Edinburgh this week and haven't stopped playing since, I just love it! However, today whilst familiarizing I found a problem which someone out there my be able to help with. I cannot get the transfer box lever to move from its "high" position to "low" position. I have followed the guidelines in the manual - engine running, main lever in "N" position, foot on the break, lift the transfer box collar and it will not move from the "high" position
. Am I missing something? Any ideas?
Thats the way it happend with mine. The first time going from high to low…..well I thought I would destroy the entire thing. Now it is always going on and out very smoothly.l imagine it will get easier with use and time.
It's also my thought that there is a principal difference between mech & auto transmissions:Hello Tony,
I know the problem too. There are situations where the gearbox shifts well. From high to low in lock low, in lock high and back in high.
But just today I had the same problem again with the lever not wanting to go down. I then went forward a few centimetres in D, then shifted back into N and went back into low with heavy pressure. From my point of view this is not satisfactory. When I look at my Land Rovers, shifting into low is much better. But that is also because they have manual gearboxes and I can engage 1st gear to let the reduction engage.
