Trailer lights wired, Dual Battery wired with RedArc isolator, sub relocated
Shawnpalmer
4:07 AM
Lake Lanier, Georgia, USA
Trailer lights added since I didn’t get them on mine, sub relocated, and RedArc dual battery kit installed. See pics.
NATO plug installed and run to battery.
It’s coming together!
Can you please let me know how you got the trailer lights wired? Where to connect etc. I did not get mine dleviered with the tow package but have since added the receiver. Any help would be greatly appreciated :)
It looks like you used this socket but am not positive. I was trying to find something the fit the current opening with the 3 3/4 eye to eye holes already in place
Would help me too ... what did you connect the Hopkins plug to inside the Ineos?
NATO plug will be added in a couple of weeks connected to Aux battery, and Anderson connection under the hood.
NATO socket will be wet up to run a rear mounted winch.
Did you add a brake controller also? Pics of that and Hopkins wire connections would really save the day? Appreciate any help available.
My local 4wd shop did the wiring, they said they used a jeep wiring kit and spliced into the wires behind the tail lights. On the back of the tail lights is a wiring diagram.
That is TREMENDOUS help ... THANK YOU !! Not to push my luck with too may asks, but any clue how to get the darn tail light off? LOL - I took all the screws off the back right corner trim and the one screw on rail outside and that 3-4' long back corner painted plastic trim wasn't seeming to budge any. I was afraid to pull too hard as figured if it broke, Ineos would be years getting me a replacement.
