Americas That darn drivers seat...
Jeffrey
Forum Donor
12:47 AM
Santa Barbara, California, USA
I love my Grenny, but the thing I most dislike, as the driver, is getting in and out of the thing. Compared to most cars, the door opening is rather small, but what's worse is that annoying hard ridge on the door side of the seat. It prevents you from simply sliding out of the car when you are exiting, and further, it crushes my nuts trying. You have to grab the bar and lift yourself up to get over the hump and then try to safely get your feet on the ground while hanging from your arm. It's quite uncomfortable. Has anyone here re-shaped the seat hump? I'd like it to be about the same height as the seat. I've been thinking of having an auto seat shop do the job but I'd probably have to remove the entire seat or at least the lower cushion and that is probably prohibitive. Ideas?
I have side steps on mine.
To get in I grab the rain gutter
Step up on to the side step and stand upright
Then just step into the car, left foot for me on rhd but for you it would be right foot first
To get out I just reverse the process.
I personally cannot stand to see ANY lower and upper bolster wear on any of my cars which includes factory carbon buckets.
IG is a sofa in comparison. I got the factory A pillar grab handle to always lift myself up and over so the bolsters don't get so much as even a whiff of my stinky bum.
Enjoy!
It reads more like an issue with the scrotum size and location. How old are you? Perhaps it’s just old man ball sag. You could be due for a ball lift, you know, get em’ high and tight like they were when you were 15 and desperately trying to contain the spontaneous hard on in coed gym while watching Jennifer bounce around with her new boobs playing soccer.
Few things worse than a lose pair of swim trunks permitting that old floppy change purse to let its contents slide under your thigh while exiting a tall truck.
This could be covered under insurance if there’s low testosterone as a co morbidity.
Don’t be offended, or ashamed, We’re all about solutions, and moving on here. Besides, there are likely other closet flappysacks looking for a solution too.
You should try getting in and out of some Senna seats in the 600LT.... lol might as well tape them up.
Side steps / sliders like the ones Owl makes, provides night n day difference.
Your height/weight/strength(leg&knee) are all factors
Modifying the seat bolster is the most unconventional solution
Had the nut issue until I purchased the side steps.
I also hate sliding on the seat bolster and causing extra wear.
It looked like the drivers grab handle I can order is larger and does not match the original passenger handle. Is an OEM style available?
OEM handle is available from INEOS, there are several threads on here about fitting the second handle.
I fitted an OEM driver's side handle and it has transformed getting in and out.
I replaced the overhead handle with the OWL(?) bar since I had issues getting my fingers under the OEM floppy one.
I’m really fat and tear up the side bolsters on seats getting in and out. I try not to just ‘slide’ out and lift over. I have side steps that help a bit.
I have more of an issue in small parking spots where I can only get to the first ‘click’ in the door swing.
I'm tall. I was happy climbing in and out without steps but the bolster was going to take a beating. My better half wanted steps for her bad back. I sprung for a set of the Owl sliders with retracting steps. Despite their price, and their steps/up form factor being larger than I was hoping, they're really quite awesome. The gutter makes a fantastic handle as well.
I generally wear pants when getting in and out, but yep can understand if it’s like a footy sock with cricket ball at the end…
Owl sliders with retracting steps?
My family really loves having side-steps to make ingress/egress easier. But my OCD can't stand changing the vehicle's profile with a big fixed running boards. I don't need rock sliders, so I ordered a set of these:
$1300 without the LEDs, and 5% off of that for new customers. They were delivered quickly and I'm having them installed in January. I like these because:
- They have 3 mounting brackets (cheaper ones only have 2) and use factory holes in the frame.
- They seem to have several Grenadiers and use scanners to create parts that fit well. Noticed this in their YouTube vids.
- They were extremely responsive via email when I sent questions.
- Once retracted, the Grenadier looks factory clean to my eye.
Note that Strek is the U.S. affiliate for Summer Auto Parts out of China.
Here's the set that I ordered:
View: https://youtu.be/8reaNRGr6ew?si=ANJJ0VdemeyYYbSW
Seems plausible
