Stuck at Cape York (Double cardan joint in the front axle failed.)
Matt P
6:49 AM
Earth
Posting this on behalf of CK Barr from the Australia Facebook group. Details here 👉https://www.facebook.com/share/p/14GA15TBpwk/?
Double cardan joint in the front axle failed. If anyone is able to help I think he’d appreciate it. He’s got two kids with him.
Needs parts sent to Bamaga in Australia. This could also be a good time to deploy the flying spanners service surely? Or perhaps Justin can help. We’re a bit remote ourselves at the moment and so I thought I’d put this in here and let the community do what we can to help collectively. 💪
I contacted Alex Collo at Purnell Adventure Sydney. Alex is sending the info to a contact at INEOS ANZ, so hopefully this will mean help.
Is there a contact mobile number and name? Or is it CK Barr? A mobile number will be helpful, as mobiles should work at Bamaga. At least those using Telstra.
They should contact the INEOS dealer at Cairns. Details are:
Westco INEOS Grenadier​
351 Mulgrave Road,Cairns QLD 4870
Phone: (07) 4044 4121
westco.sales@westco.net.au
They should be able to arrange replacement parts.
For our foreign friends this guy is just short of the northernmost tip of the Australian mainland in a very remote community. He is 3400km (2110 miles) from Sydney and closer to Port Moresby in Papua New Guinea than the nearest Australian city (Cairns). A tough recovery due to the logistics.
Bamaga
The same scenario was discussed "Not an Ineos axle breakage. What would you do in this situation? "post.October 24.
Hopefully it's sorted quickly and can be reported back here and on FB as another positive experience for after sales service.
Seems fairly unambiguous to me, one of the compelling reasons I purchased early instead of.. dare I say... Txxota
Just need to demonstrate this.... walk the talk so confidence grows in the product and after sales service. 😀
OFF GRID SUPPORT​
We want to support our customers off the beaten track. So you will have access to workshops even where Grenadier isn’t sold. Alternatively, if you want or need to work on your own vehicles, you will have access to remote technical support from INEOS HQ. That could be by text, telephone, email, or in the shape of online manuals. If it’s a real emergency, our ‘Flying Spanners’ technicians will even fly to remote locations to keep your downtime to a minimum.
24-HOUR PARTS​
We know that customers depending on their Grenadier can’t afford costly downtime. So we are aiming for 24-hr parts delivery in major markets, thanks to a central logistics centre, regional hubs and logistics partners.
OFF GRID SUPPORT​
24-HOUR PARTS​
They were in contact with help quickly, but they will wait for freight to Bamaga - like most other brands.
This is the first time I've heard of this failure. He did mention the joint has clicked since day 1. Faulty part/install?
''My front double uni’s have always made clicking sounds and noises from factory when in center locked"
There have been a couple faulty joints mentioned in other groups. The reported failure rate is extremely low, not a major concern.
I guess the other thing to mention is to be wary of using front diff lock, especially if you are steering hard. Not IG specific, just the weakest link. (From experience)
I'm not suggesting the person in question did this.
Looking at the photos it looks like the lube washed out or was contaminated and the UJ siezed , everything is dry it doesn't look like a sudden diff lock induced failure.
I'd check for part numbers and also measure the UJ itself. The cap diameter, the overall width cap to cap and because this is a DC joint the distance between the two joints. Universal joints are commonly used in all sorts of equipment, I once fitted the UJ from a tractor PTO shaft onto the drive shaft of a LR discovery. It worked fine for years.
I'd check with any agricultural or mining suppliers in the area and give them the measurements you might just get lucky...
I wouldn't disagree, that looks very likely. As I said, I wasn't saying that diff lock induced this particular failure.
Before I read about the clicking joint, I was going to suggest someone ask the fella if he is an adopter of adjusting the knuckle stops, for our reference. If one does a lot of off pavement with the truck, one will spend a lot of time at the stop limit.
I am not an expert on U-Joints, but with the number WAL 310 on it, it might be a Walterscheid brand, which would not be uncommon for a Carraro Axle.
That's a private page, so, I don't know if I'm seeing all pics... Is there no centering yoke on the DC, or are there parts lost in the explosion?
Well done! I bet thats it. I think they are also found on the IVECO 4x4 Daily. So thats another avenue to try...
