Steering stabilizer bar
Sadly that is not everyone's experience. Some are even finding the steering to be borderline dangerous at speed.
I actually find that hard to believe. Wife and I drove 4,000 miles last summer for a trip out west. Just took 10 days. No issues at for me driving 10 hour days and never once felt that it was dangerous. However, at almost 70 years of age perhaps my experience driving exceeds most on here.
Or you sense of lane control has diminished over time 😂
Well, somehow I must have dodged that classification because I ran no power steering most of my 20's with 40" tires, clearly I'm no real man. 👨 🤷🏻
Neither of us are young pups now.
Do you take the steps or look for the elevator?
Greetings from Dubrovnik!
I don’t mind the stiff steering wheel in local driving and helping with the return to center. My main issue is the squirrel like steering on the highway. When I look down to adjust air and look back up, I notice I’m wandering out of my lane!
you gotta keep at it with the dealer. They replaced a bunch of rear control arm bolts on mine and did a whole procedure to align the axles from the beginning like it was just built, and now I'm running a stock stabilizer, higher pressure in the tires, and it stays in its lane, tracking like a Ford e350 thats new, not 50000 in where where you feel like you're in a 2 hour tennis match with your left arm.
I suspect some of these came like mine, with a rear axle slightly out creating a thrust angle, and they fixed it at the factory by jiggering with the front alignment, which due to SAI and other angles will not work 100%. Insist on a complete alignment.
Interesting. Thanks for sharing this.
I have no problem with my steering and feel comfortable at 70mph on motorway. The only time I felt wandering was when I first got the vehicle and the tires were pumped up too hard.
Same. With a lower tyre pressure and a few thousand miles on the clock, personally I don't see what all the fuss is about. I don't have any issues with the steering. The turning radius could be better but you can allow for it in most situations.
There is a definite variability between vehicles. My Grenadier with the OEM stabilizer requires constant corrections when on the highway and has a pronounced pull that multiple alignments have not rectified. A loaner Grenadier that I was given during a service appointment suffered from no such issues. It tracked perfectly straight with no need for constant corrections. Other than the wide turning circle and limited return to center it felt like any other modern car. The question is what is the cause of such disparities between different Grenadiers.
I've had the adjustable Fox stabilizer on for almost a year and it still wanders on the highway. Tire pressure is 34 all around and I've had it aligned. Maybe I don't remember how it was without it, but my two Jeep JL Wranglers with 35" tires actually wander a bit less on the highway. It's a MASSIVE improvement around town and I highly recommend it, but it didn't make the gren a one handed drive on the highway. I think it really comes down to what you're used to driving or what you're comparing it to.
I think you are correct.
Mine self centres unless a sharp turn out of a junction, then needs the last quarter of a turn to centre.
On faster roads I can happily steer one handed. (KO2s at 34psi)
I don't think I am any better/different driver than most on here, so, yes there must be some variability in the setup.
You might find it worthwhile to experiment with tyre pressures. 36-38 psi (cold ...say 50-60 degF) all around rather than 34psi which is a tad on the low side. Slightly higher pressure will harden the side walls and may help reduce the wandering. Also, have you experimented with different stabiliser settings?
