Statistics/Poll Thread: Front driveshaft CV joint failures
the data in the poll is fun but useless and subject to selection bias. The only good data is going to be the warranty claims with the mileage of the fail. It would be nice if they were collecting lift data with the claims but who knows. Highway miles v offroad? Doesn't matter. They just need to look at this rig, and see what the trend is as miles stack up.
Mine is just a stock DD, and it failed at 22k and 2.3* caster..
Looking at the scraped data I think I gleaned some interesting information even with selection bias. Nice to have visibility to something if you are dealing with this issue
Ineos changed the part number. You don't change a part number on something that isn't broken.
Currently you could assume that qarranty coverage depends on geography. In Australia, lifted Grenadiers are getting full warranty coverage, even with aftermarket suspension. In the US, stock vehicles get covered while lifted vehicles with the identical failure mode get denied. Same boot. Same tear. Same mileage. Different answer.
The self-repair population is invisible to INEOS. Some owners never file a claim, they assume their lift disqualifies them and buy a $200 TeraFlex.
You're right that what actually matters is the survival curve. Boot integrity as a function of miles/cycles at a given CV angle. That data is much harder to get!
I
I really don't think the part number change reflects any meaningful actual part change. It could just be a different sub manufacturer or something. Externally they are identical more or less. The joints being used have been in production for some 20yrs or maybe more. And these joints failed even before the Grenadier in identical fashion.
And you are right about self repair, but.... I did mine out of warranty because it was easier for me. And hell my dealership is only 15min away. It's not a fault of the dealer, it's a matter of my time and energy. I was able to swap mine over in less time than it took to drop truck off and deal with service. Plus it helped me get to know the Grenadier better etc. And additionally I didn't have to unload all my crap and move it to a loaner or just generally be without my truck for a week or so.
The factory boot feels "dryer" and less pliable than the replacement, the factory shaft had been painted which may be the cuase of the dryness from over spray, but they feel very different to touch
The factory boot feels "dryer" and less pliable than the replacement, the factory shaft had been painted which may be the cuase of the dryness from over spray, but they feel very different to touch View attachment 7923019
They are are basically the same. As @Dokatd has proven, the primary cause of the damage is from the boot being crushed between the shaft and the metal collar. It isn’t really a playability issue as much as a clearance/contact issue.
I understand what you are saying, but the rubber is quite a different compound. If what he says is true, then why are non lifted Grenadiers boots failing?
