Spare tire
ADVAW8S
Global Grenadier 0044
Quartermaster Owner
11:50 PM
WA, USA
For those that changed the tire size in the tub, at what size did the sliding bracket no longer work. The notch is 2 inches long and I think a 33 should work without an adapter
I can't actually answer your question, but a 33" tire at the hub would only sit ~0.75" taller
I finally got my spare Wildpeak AT4 W 255/80R17 installed. I then threw it in the tub and sure enough it bolts to current location. I don't think anything taller will work. So I am going to make it official the largest tire to fit in the tub is a 33 without modification to the spare mount. Pictures are with the Wildpeak
How bad would it be to keep the factory spare and run larger tires on the Grenadier? Every full size spare I have ever had never gets in the rotation on the vehicle and it seems like it just goes to waste. Plus the extra weight on the door is a concern and the back up camera will need to be relocated.
In the event that you need to use it, it would be quite bad. The back up camera doesn't need to be relocated, only tires >34" impact the view at all
