Snow clogging headlamps/headlights
How about heated ‘rests’ for the windshield wipers so that they don’t ice over?
I cracked my windshield by turning the front defrost onto high fan and high heat- my go to move for keeping the wipers and the windshield ice free. SNAP- The air gets too hot frankly. My son noticed that, but I didn’t think that it would be hot enough to light off the windshield.
Lucky you! My HVAC doesn't generate anywhere near enough heat to crack a windshield. Though they do manage to crack for no reason. Had two replaced in 2 years.
I seem to recall back in the day some aftermarket company selling flat bits of transparent plastic headlamp 'protectors' that fit over the headlamp surrounds of Land Rover Series 3 and Defenders using the existing surround fixing screws to hold them in place.
Reactions: CRH
I was thinking that with the possibility of 3d printing and to easily purchase anything from the internet most of us (probably not me) could easily mock up this kind of thing at home at very little cost. I'm sure there would be a market for the less competent if necessary, they may even be able to make the light transmit somewhere near to how it should
Did you turn on the front defrost as soon as you started the car from cold? If yes, that’s definitely a problem. What was the outside air temp?
If I recall, automotive windshield glass is usually designed to handle about 140° F in temperature differences. For instance, I’ve started my car at -50° F, immediately turned on the defroster and eventually get to about 60° F in the cabin (with the radiator airflow blocked off) about 30 minutes later. That’s a 110° F difference from the inside to the outside of the windshield glass - and no cracking. I do know some people who turned the defroster on full hot onto a -40° windshield when the engine was fully warmed up and cracked a windshield, but even then they usually started with an existing chip or crack.
I also remember windshields getting cracked from shock air conditioning in the 1960’s, but not in the last 40 years or so.
Reactions: CRH
Can we not add a piece of clear plastic over the lights, as has been done with the various grills/light protectors? Snow won't build up in the light bowl area. If necessary it could be angled to encourage snow to slide off. Not sure on any legality, just a simple solution
Back when many headlights were 7” round (in the US), you could buy a thin clear plastic dome that would mount under the headlight retaining ring. It would stay cold and generally shed water, snow and ice. If ice did build up, they were still flexible at low temps - you could tap them and any build up would fall off. I believe they were made of Lexan (polycarbonate).
I think we sometimes complicate what can be done simply, and cheaply. A bit of cheap plastic shield, although probably not legal, but who is checking that in a blizzard 🤔
