Signals to trailer lights not working - any solutions out there?
Mallig
9:03 AM
South Mississippi
I spent the day yesterday installing a REDARC Tow-Pro electric brake controller. Not at easy as it should have been since one of the wires (violet/orange) didn’t work properly. I found the workaround on this thread thankfully: https://www.theineosforum.com/threads/na-trailer-brake-controller-install.12414979/
After hooking it all up I connected to my Dad’s trailer and discovered the Grenadier wasn’t sending the proper signals to the trailer lights (the brakes worked though!). My Dad’s trailer is older with regular bulbs so we drove it to a friend with a trailer that used LED lights. My friend said all the trailer lights worked with his truck, but when we hooked up the Grenadier everything seemed to work except his left turn signal light. Hazards, brake, and turn signals all worked with the right light but not the left. Also, with both trailers connected my Grenadier showed an “Exterior bulb failure” error on the dashboard.
I should mention I discovered the trailer signal issues last year and brought it into Mossy in Houston in October 2024. They looked up my VIN and said the software update that was required to release vehicles with the tow package had never been performed so they did that (I purchased my vehicle from Triad in April ‘24 BTW). Unfortunately I never checked again until yesterday.
I’ve read there was ANOTHER software update to fix a small number of vehicles that were still having trailer signal issues. I’ve also read something about possibly needing resistors depending on the type of lights your trailer uses.
My current SW version is SW0000000773003070
My VIN is -01161
Anyone have any insights they can share? I’m about 6.5 hours from the dealership so if there is something I can try first on my own I will.
I use a trailer light tester. See if a friend has one compatible with the Grenadier trailer plug.
I changed my plug from the 13 pin Euro to the more common 7/12 flat pin used in Australia. I bought a tester and have used it a few times now, not just on the Grenadier. It made my life much easier. Even better if you can borrow one.
Yep, my trailer light tester throws wonky signals too. But it uses led lights so I wasn’t sure if a resistor was needed somewhere.
I have a similar problem. The turn signals work and the stop lights and electric brakes work (Redarc controller) but it seems regardless of what I do the stail lights and side lights on my large trailer - when it has not been connected for a time - do come on for a time, and then the car seems to disconnect that power feed.
The trailer has LED lights - and I was advised to change a light in that trailer circuit to halogen - same situation, lights extinguish after a short period - so I was then told to put a resistor in the feed to the trailer lights. That was done, and yest everything worked again, for two days, then the lights failed again after a short period.
Any advice please?
My VIN is -01161
Did you get this sorted?
Not yet. I brought the vehicle back to the dealer for the second "software fix" but when we plugged in my trailer light tester it was still not showing the proper signals. To be sure the tester wasn't faulty, we plugged it into one of their 2025 models and the tester lights looked good.
They weren't able to further diagnose it that day so I scheduled another trip out to the dealer. They spent that day tracing wires and troubleshooting with Ineos and in the end decided to order a new trailer control module. Since then the TCM has come in but I haven't been able to make it back to the dealer. I plan to go in mid-November. I'll provide an update on whether that fixes the issue.
Hooking the vehicle up to a 4-pin trailer using a 7 to 4 pin converter does work, so my issue is when using a 7 pin trailer.
The service tech (at Mossy in Houston) told me this is the first he's seen this issue, but I suspect there are lots of US 2024 Grenadiers with this issue. I have personally put my 7-pin tester on 2 other 2024 Grenadiers and both gave erroneous signals.
I had the trailer module added after purchasing.
I'm in Canada. The trailer has red brake, turn and hazard lights - all the same bulbs, not LED. I was using a 7 to 4 flat connector.
  • The marker lights work.
  • The hazard lights work.
  • The turn signals do not work.
  • The brake lights do not work.
  • On the vehicle dash, turn signals are indicated as if working.
  • When the brakes are applied a trailer wiring / exterior light error pops up.
With an LED tester, the same as above, except there are no indicator or error messages.
Obviously the vehicle is able to power the turn, brake lights because the hazards work. What could be wrong?
Is the module the same one for all regions and needs to be programmed or configured for North America?
But even that wouldn't explain my symptoms: Even if it "thinks" I have amber turn and hazard signals, then both should work.
Sorry for the delay in updating, but my issue is still not resolved.
I dropped the vehicle off with Mossy in November and they gave me a brand new Grenadier as a loaner, which was awesome.
The plan was to leave it with Mossy for a week to install the new trailer control module (TCM), fix leaking A/C condensate on driver and passenger side floor, replace front drive shaft (torn rubber seal — yes I put new HD springs in last year to level it), and fix the front pinion gear seal (it was weeping).
They replaced the TCM but that didn’t solve the issue. Another TCM was ordered (apparently there is a new design with a new OEM number?). Ordered, arrived, installed, still not working properly.
I had to pick up my vehicle after that. It had been with Mossy for about a month and I had a trip planned to NY (I live in south MS) and of course they didn’t want that many miles on their loaner (understandable). I now need to figure out when I can take it back so they can troubleshoot it some more.
Also, the A/C condensate is still dripping and the pinion seal still weeping. Goodness this is starting to get old.
If anyone has had a similar issue with getting the proper signals to their trailer and have found a solution I’d appreciate it! If adding a resistor would might help I’m game to try it, but not sure where to install it?
I’ll be dropping the IG off on Friday at Mossy Houston so they can troubleshoot the trailer light issue some more with Ineos. In the meantime, I wanted to bump this thread with the hope that someone with a NAS vehicle may have had the same issue resolved and could share the fix?
