Show us your mods.
I replaced the six Torx drive M10 x 1.5mm x 22.5mm bolts holding down the plastic panels beneath the rear seats. The first time I had to remove these bolts, I had to press a Torx bit out of its 3/8" drive holder, then use a small ratchet to drive the tool from underneath the seat bars.
The new bolts are internal hex drive M10 x 1.5mm x 25mm with washers. Now I can install or remove the bolts with an Allen ball driver - much easier. I have to wonder why Ineos used such large fasteners (with thread locker!) here - a small screw with a fender washer would have worked quite well.
New and OEM fasteners shown here:
Here's how a ball driver fits in one of the new bolts:
Neat idea @Glen. Thanks for posting
These work quite well too from Agile, got a set when I was installing my under-seat compressor kit from them...
That's cool - I had no idea those were available. AO has a lot of nice stuff - I have a fair bit of their kit on my Grenny.
I haven't done the side by side comparison but I wonder if these large fasteners are for the hard lid that is used for the two seater commercial version? Agree they are overkill for the plastic trim.
I speculated something similar - they had to have originated from a different application. Each bolt can supply about 23 kN/5,300 lbs of clamping force - that's a lot to hold down a plastic trim panel :)
Since it's now illegal to drink drive in Australia, I converted my drink holder to a bin with USB ports.
