Show us your mods.
Hi folks,
today I test mounted the Strands SIBERIA LED Bar with the custom 3d printed mounting brackets… Looks good and the measures fits… Next step finalizing the design and getting the metal job done…
For the wiring I‘ll need some help…
Thanks, @DenisM yes, I thought about it, the bar only blocks the lowest part of the grille and I hope it will work. Otherwise I‘ll have to remove the bar.
Working with someone on Etsy to tweak his Element fire extinguisher mount design, he came up with this to mount on the Grenadier USA cargo wall track I've installed in the rear. Will post more pics when installed but should be available for purchase in his shop soon...
Did you have to cut the grill for that?
No. I used these brackets from the forum store:
They fit perfectly and are superb quality.
The KC’s are expensive but feel very well made, obviously have a good reputation for quality and are very, very bright with a lovely wide spread of light
View: https://youtu.be/3ZJa36vCBO0?si=0_yd3KFUmX0Kncvi
Now you just need these pods.
Very nice.
I am assuming you can wire those up to turn on with the flick of an overhead switch?
Thanks
Very nice.
Thanks
In UK they work off the aux light switch on the roof and then the main beam on the cooling stalk.
You can wire them to act as sidelights but I’ve got them set just to come on with main beam - with the roof switch armed of course.
