Sentinel vs XLR 80 vs Linear 18 vs LP6
GrenAF
12:58 PM
Long Beach
Currently contemplating which light to replace my factory auxiliary lights with. I know the sentinels and baja design lights are popular but would love to get some real world feedback on what's working well and what's not.
Based on the incredibly informative whitepaper by @parb I was able to determine the following 10 lux distances:
  • Sentinel Elite 194.65m (beam spread at 10 lux unknown but likely higher than the rated 65 degrees)
  • LP6 143.56m @136 degree beam spread
  • XL-R 80 119.5m @62 degree beam spread
This tells me that the Sentinels offer the highest level of performance but something about permanently altering the grill has me hesitating. I do love the look, however. The author of the whitepaper ultimately chose the XLR80 but it was being supplemented by a roof mounted light bar which I prefer not to install. The XLR80s offer the least 10 lux distance but have the cleanest install that's fully reversible.
A few questions, what are people running for fog lights and is there anywhere low on the bumper to mount them?
With led technology becoming smaller and brighter, any chance of regret down the line from mounting the sentinels? if so, what brought you comfort to permanently alter the grill?
Are the XLR80s good enough to be a standalone front light or do they require supplemental lighting?
Are ditch lights mandatory? If not, do any of the above provide adequate cornering illumination? Obviously the LP6 but I find the look the be the least discreet.
Does the hidden 18" lazer / triple R light bar provide any functional value in addition to the above 3 besides aesthetics?
4wd is Life on youtube does a bunch of good comparisons of led lights.
I have the 5" Auxbeam fog lights and they are fine for me but they are not DOT approved. For fogs DOT approved is going to be more versatile. But I'm more of a low speed high drag offroad driver. At reasonable dirt road speeds your not going to out drive your lights.
You wont regret any good quality light unless you fell the need to constantly upgrade. A good light today will still be a good light tomorrow.
I don't care for ditch lights or roof mounted light bars. Too much reflection off of the vehicle. I'd rather have a bull bar and mount side shooters to that even though you loose some reach because of the lower mounting point.
The hidden 18" triple r lightbar is really good. That along with a set of fog lights and you would probably be happy.
Any suggestions on best place to mount fogs? I've seen some put in the intercooler slots but that seems unwise to block the coolers.
Given its recessed location, does the Triple R light bar still have good UPWARDS beam spread (e.g. as you drive down into a gully, can you see well what is ahead and ABOVE for your inevitable climb out)?
I mounted mine centered on the bull bar.
I think DVA makes a light mount bar that attaches to the bumper if you don't want to run the full bull bar. https://dvamechanics.com/products/i...bar-clean-factory-integrated-lighting-upgrade
remember i got my XL80s well before the sentinel grille lights where out. i may have picked those today, they are a solid light.
i am not so sure i need anything besides the XL80's for most driving. the light bar on top is realistically only for true high speed driving.
i have since then added ditch lights to my setup. RRE brackets and the Triple-R work lights. Mostly useful on tight forest trails, but i like them.
I have yellow caps for the baja and the triple-R for dusty or snowy conditions. They come off when in normal driving environments.
I have the owl mounts + LP4s in the factory location tying to EXT5 25A power source in the engine bay. While doing that, I ran the Triple R hidden light bar to the EXT1 10A pair right next to them in the engine bay. The daytime run function is stellar on both, and the LP4s throw a crazy amount of light from the factory location. It’s a very clean looking install.
The LP4s with the drive combo lens give a good amount of throw to the sides, and I really haven’t found a need yet for dedicated ditch lights.
Does the light bar provide additional coverage in terms of spread or range? Do you find it redundant at all or supplemental? Trying to find the best combination of lights and the light bar in elite plus form is very compelling.
Redundant from a coverage perspective. The hidden light bar provides a sweet daytime run profile when not running on full power mode, but that’s probably it. The LP4s are just so effective at throwing an obscene amount of driving light midrange. Supplemental would be adding 2 additional LP4 spot lights for better long range throw, but the cost on that in significant. I’ll let you know how the 2 driving LP4 and 2 spot LP4 configuration works once I get the spot lenses installed.
FYI though, I would just buy clear LP4s if you find yourself in a 4 LP4 situation. Spot and driving lenses are only available in clear; amber lenses only some in driving and 4 of those seem super redundant. Plus, you can always add amber rock guards to the clears to get the best of both worlds.
Current setup, but making the LP4 changes within the next week or so if work slows down. Rock lights are just for hunting when we don’t want to lose night vision when coming/going in the dark.
I’ll add a visual comparison from the point of view of the driver when completed.
