Safari window cover
ADVAW8S
Global Grenadier 0044
Quartermaster Owner
2:47 AM
WA, USA
Late last fall, I got to thinking about the amount of pine needles and leaves that fall iny area. I also knew that my QM would have safari windows and I would want to clean the area on regular basis. I thought of an idea, magnetic cover to go over the safari windows when stationary. @OverlandGearGuy stepped up and created me a cover. I used it last night test out because I have some safari window leaking when it rains. Ineos can't get me in until June 9th. Sure enough it stopped the rain from getting past the seals. I think this is a must have for the fall.
How much were they, mine seam to leak due to the angle I park no matter how many times they have a good at repairing, although I haven't tried the latest go. I have thought about something similar.
So nobody has left the roof open and had a snake , bear or lion crawl in yet?
I just get spiders, especially huntsman ( the ones people call tarantulas, because you know all big spiders have to be tarantulas...".
And they sneak into the petrol filler hatch, sometimes setting off the driveway attendant's alarm 😄
I don't recall because it was so long ago. Maybe @OverlandGearGuy can jump on and give you a quote.
I have dampness/wetness in the corner of both A pillars and extends to center of the side windows. I wonder if it is the seal or the drain hole as if water sneaks underneath the rubber plug.
Checked top of windscreen seal?
It was $129.99 for the cover we made over the Safari Windows
Rob
OverlandGearGuy.com
Rob
OverlandGearGuy.com
Thanks, i will test the latest repair and if it doesn't work, I will be onto you for one.
Unusually for UK we have consistent sunshine!!
When I lived in Tassie I had quite a few spiders inside the cars.
Shows you how good the dust/water seals were.
It's disconcerting when they run across the windscreen when driving, on the inside.
More so when your wife says "don't look up"
Seals are fine in many instances.
They live in the door jambs and scurry in unnoticed when the doors are opened.
Too bad if you are a jumpy sort of person.
This is why the wife will NEVER go to Australia, sadly
