Rooftop Solar on Factory Rack
Tom109
11:55 AM
I've been planning solar support for my Engle MT45 for a while and finally have everything on-hand. It is a very simple system - factory dual battery set-up remains unaltered, the MPPT will be connected to the main battery allowing the 120s to meter charge to the auxiliary battery. The main components are,
The system is planned as a full-time, semi-permanent installation. The panel will be mounted flush to the front section of the factory Rhino Rack. Panel brackets will be cut from aluminum angle, minimum four mounts depending on the final rack slot alignment. More details to follow as I start the installation. First order of business is choosing the cable route from roof to battery...
It looks like a sound design.
My solar panel is connected to the 250SE (mated to the 120S), cable routed down the B pillar. 160W solar panel. Secured using stainless steel eye bolts that I can attach tie down straps too, for more functionality. Using beefy L brackets from the hardware store.
I used the same design on the Nissan Patrol and the solar panel stayed in place after the massive head on and the panel was not broken! A field tested design.
full
Baby steps. I cut the feet and they are currently sitting with a coat of etch primer. Tomorrow they’ll get a UV topcoat in black.
You need to be careful when you drill the holes into the sides of the solar panel, allowing sufficient space from the panel surface, so the nut can be put on and tightened.
Place the nut on the side of the panel and work out where to drill the hole. Use the nut as a template.
This was the part of both installs I held my breath, as you must get it correct. I came close to getting it wrong, but managed to tighten the nut with about 1mm to spare.
Successful snake run! The green (plastic coated aluminum) wire shows the path from the battery box. I removed the front LH toof tie down assy and in the opening you can see the end of the green wire with blue tape flag.
I’m still playing with options routing the cable to the roof. I have a handful of various seals to test, as my original plan to exit within the Deutsch connector cover proved too congested. That said, I could just eliminate the Deutsch connector all together. :unsure:
I'd say stick with a connector (and a second one inside) in case you ever change to something else on the rack - even if only temporarily. Run the wires out through the smallest hole and grommet you can. If you ever need to retract the wiring you can de-pin the plug with the correct tool.
I hadn’t thought of an additional set of connectors behind the grab handle. If I ever remove the roof rack I had planned to zip tie the extending cable to the lashing bar. Access to hidden connectors would require removing the whole lashing bar assembly as I figured out a grommet & seal method that utilizes the existing hole for the Deutsch cable grommet.
Hmmm :unsure:
For clarification (of previous errors), the two PV cables (+ and -) are 10AWG. Each is ~6mm diameter. The MPPT power cables (+ and -) are 6AWG.
The solar PV connectors , while rather long, are IP67 rated. I have three sets,
  • 1 pair on leads from panel
  • 1 set inside lashing handle cover (only for the rare chance I remove the roof rack, e.g. next owner problem)
  • 1 set in battery box w/20A fuse (+) inline to MPPT. Bare wire ends feed the MPPT.
Removing the LH forward lashing handle cover, I can see the inside (behind headliner) deutsch connector, that feeds the exterior deutsch connector. This would be an easier way to access this connection for repurposing. In hindsight I should have run another wire for this reason! Since I will not use this external deutsch connector (it will be the PV cables entry point) I may just disconnect and remove the external deutsch pigtail.
Family is arriving for the long weekend, but I hope to get early morning in the garage to finish this project.
