No it’s not, the Grenadier is a 105ah. I’m sure @Clark Kent just put that battery as an example Molle EFB battery as the Grenadier one is not listed on the Molle site I understandAre you sure the Moll 82064 is the model installed in the Grenadier?
No it is not the one installed, as the 82064 is rated at 64Ah, whereas the INEOS Moll battery is rated at 105Ah.Are you sure the Moll 82064 is the model installed in the Grenadier?
Yes, this. It's the EFB chemistry that matters here not the specific battery model.No it’s not, the Grenadier is a 105ah. I’m sure @Clark Kent just put that battery as an example Molle EFB battery as the Grenadier one is not listed on the Molle site I understand
You're likely a part of the majority here!I am old enough to remember when starter batteries were measured in cca's.
What is this AH madness, need alternators that can generate enough eleccy to keep the bit'n'bobs going, and batteries that can start an engine then go back to sleep after a refreshing recharge, that takes about 30 seconds.
I am guessing that the battery needs to be disconnected so as to not add more load to the charger(?)
Ineos answer. They recommend a Bosch C7 12v 7amp battery charger which has a six stage profile.
Not much info online and can’t find a new one for sale in the uk. Looking at the Bosch website for C line chargers and there is no C7 only starting with C10. Which charges at 14.7 volts.
edit. The only difference i can see on the Victron kit is the absorption charge between 14.3 and 14.7 v on different AGM batteries.![]()
Bosch C-Line battery charger
The new Bosch C-Line battery chargers: Now with higher performance and an extended range of functions. Five device variants for individual customer requirements.www.boschaftermarket.com
I’m still confused. Doing your own thing I guess
edit it seems the C7 has been superseded by the C10 so slightly out of date advice.![]()
I am extracting the key data from this discussion into Resources here:
Resource icon
Charging profiles for the Moll EFB battery
I think we need to change the bit about the C7 charger as it has been superseded by other Models. All of the Bosch C line chargers have an EFB profile and will automatically detect battery type.I am extracting the key data from this discussion into Resources here:
Resource icon
They must be dumping all the C7s in Australia, where they seem readily available.I think we need to change the bit about the C7 charger as it has been superseded by other Models. All of the Bosch C line chargers have an EFB profile and will automatically detect battery type.
Many do, NOCO calls it repair mode, CTEK recondition mode and Bosch regeneration mode. All charge well above 14.8 volts.dont all charges have this, specially the ones that advertise 'can charge from dead' ?
In those 3 brands they are a separate profile, at least the manuals I was looking at.
If you use a trickle charger or DC to DC charger with the correct charging profile, batteries do not die early either.TI think if the battery is dead then is pretty buggered anyway![]()
