Ronny Dahl Bought a Quartermaster
Watched the video about the half box. I would prefer a 3/4 or full canopy box. Ronny makes a good point about keeping the weight centered while driving on the more technical challenging trails. However, he is comparing it to the full box that is loaded to the gills for adventure touring. If he had stripped out all the adventure touring gear and kept the heavier items in the same location as the half box I think there would be very little change in off-road performance. I would bet there is less than 50 lbs difference between a full box versus the half box.
There is a massive difference in weight in half box and full box of your doing the Norweld deluxe, which I believe he is doing. The half box 353 with drawers versus 617 with drawers. Now if you do the basic empty, your looking at 234 versus 317.
Half box is the way to go, yes I am basis. But if I was doing nothing but touring and was never going to use my truck for truck things, then compact makes the most sense. What I love about my set up is the tire is now underneath. Where Ronny is in tub and you are eating up space. I have a full 3 feet in length and 6.2 inches in length plus similar dimensions in the box.
Thanks for the info. I’m pretty sure I’ll still go with a full version of the Couch box but it will be configured like your half box up front and empty on the back half to use for truck stuff… We get over 75” of rain here every year and I need too keep stuff dry. Love the idea of the spare tire underneath too. I wonder if it will work with a 35x11.5 tire that I’m now running. BTW - I’m running the 1000+lb springs in back and 250+lb up front.
I only get 74" of rain here in Kirkland. My set up for under tire can go to 35. The new exhaust set up limits going bigger. Plus at 37, might as go portals.
Jay and I decided on 500lb which seems to be the sweet spot with the half box. I'll add airbags later on for more weight support. As a daily and unladen, 1000lbs seem it might be to stiff.
Does Ronny have an auxiliary fuel tank underneath, hence his spare location - I’m guessing he does?
When you do there is really no room to spare for anything apart from airflow.
He has the 106lt LR tank, so no chance.of getting a spare anywhere underneath
Every thing we do is a compromise, Ronny's full canopy/tray was ~ 450kgs without internal fit out. Mine was 250kgs.
I personally don't see the point in the half tray for touring as dust covers everything in the back. Even doing some decent tracks the canopy didn't feel heavy or unbalanced
He has the dual tank version, 168 litres.
He does and I don't. And as @MrMike points out, everything is a compromise. I n America, I don't have to travel long distances without being able to get petrol. If I need to carry gas, I can do Jerry Cans, I calculated I can carry 4 of the 5 gallon cans against the back wall. I still will have space to carry my other camping gear. Dirtbox, is working on a under tray gas tank to work with the spare down below.
There is no perfect set up, the perfect set up is the set up for you. I don't like full canopy set up for how I will use my truck. But I also know, there are things that I will have to deal with my set up versus what people have to deal with in their full and compact canopy.
Also Issac said you can't put a spare underneath. We proved you can.
Is there an auxiliary tank under there as well and if yes, what size is it?
Under my tray, no aux tank, just the tire. Jay Couch the guy who designed my tray, is working on a aux option. It's in the design phase,
