perhapse. work on it some more, and i'll let ya know."Wedment" is perhaps a typo for "weldment"?
I've no idea what a "wedment" is but I know what a "weldment" is.
Back from the dealer last night, new rear diff installed. Still no technical conclusions other then a mechanical failure. However, after the dealership had the first road lock they were able to repeat it consistently, so the problem would have grown worse. A few thoughts;
1. Be sure to know the warning signs as this could be dangerous. Extremely long delays getting the rear locker out. Say 10 minutes or more off road, rolling backwards, taking it out of center lock does not seem to get it done. And and chirp of tires on road especially with dash lights on a turn.
2. yes, its rare. HOWEVER, 2 more have cropped up since mine in October. 1 other in Colorado and 1 in Illinois. So while not wide spread yet, we now have 3.
3. Cost according to dealer to replace complete rear end 14,780.00. However parts are available to fix the mechanism, but the dealers have no technical direction yet and Ineos needs to understand the problem.
4. Initially only a little metal in diff, but dealer did another diff fluid change while diagnosing and the fluid became dirty right away. So again, verifies a bigger issue was coming.
5. Diff came from Belgium, total time from diagnosis, claim approval and fix about 6 weeks.
Currently this is a rare occurrence and we have no idea where it will go. So just be aware. If it becomes widespread it will have to be a safety recall like the drive shaft issue will have to be.
Curious…as crazy as it might seem, is that an argument to turn down a warrant claim?In other applications with locking differentials, I have found the quality of gear oil to be a major factor in how well the locking diff operates. I've just changed all the gear oil in my Grenadier (both diffs and tbox) to high grade Motul Gear 300 75W90. The factory fill and spec is basic Dino oil. This stuff is much "slipperier" and more stable to degradation.
They definitely wanted mine. I sincerely recommend having that done on time at a dealer.That was what Ineos has been throwing at us. I think they have even asked for proof of oil changes. However, I don't buy it. The first time I changed the diff fluid it was clean. 2K miles later it was roasted from locker failure. In my Power Wagon I usually do every 100K - 125K...and it has a LSD. Granted the last generation would not lock the front at all due to Nannies, lol. The mileages are too small to be oil related.
No. It's the same spec of fluid (GL5) , just of higher quality.Curious…as crazy as it might seem, is that an argument to turn down a warrant claim?
Full rear axle replacement is apx $12,500. It is cheaper than rebuilt..Back from the dealer last night, new rear diff installed. Still no technical conclusions other then a mechanical failure. However, after the dealership had the first road lock they were able to repeat it consistently, so the problem would have grown worse. A few thoughts;
The failure point will just be part of the locker mechanism, cheap to fix once they know what to prescribe.
