Rear cargo light
beg
12:17 AM
Scotland
I'm looking for a light solution for cargo area as I've fitted a cargo shelf and now need a light to fit underneath it just wondering what others have done to fix this . Also does anyone have a link for the overhead panel 3d signs . Cheers
Just noticed this.
I fitted a couple of number plate LED's via the internal light in the boot area, I patched into it with a new piece in loom and ran a cable out too the plastic cover over the top door locks. Reasonable simple, the biggest hassle was making the loom up with the itsy bitsy electrical connectors. not easy for big paws to play with.
I put some info here
G.
Check out Kingpin I mounted three in the cargo area, one above each side window and one on the rear door to light the table work surface. Used INT2 for power and added their dimmer switch.
This is what I went with. Not sure if I posted it previously but I mounted a long one on my cargo shelf and spliced the wiring to the light in the ceiling.
I can post some photos of my setup when I’m back in town, wiring was pretty straightforward and I hooked just the two on the windows to a dimmer switch since they’re a little tough to reach with cargo area full.
Thank you. I actually bought that extra switch from Kingpin but I never installed it. Vehicle wiring scares me more than house wiring. I actually had a parasitic draw on my battery because the wires for my Suma mirrors found there way to connect to each other behind mirror and caused my battery to drain. Good thing I am not a vasectomy doctor. :)
I put the shelf in mine from KAON, and immediately found the roof light was compromised. I bought one of these, and the pocket clip means it hangs in the middle under the shelf, and I can move it if need be. Very easy solutions. I couldn't be bothered with the wiring. I only use it occasionally, and I can move it around when I need it elsewhere. Very happy with it.
If you add the Kaon side molle panels you can mount two Stedi rock lights and run them off the roof light connection.
what are you guys wiring into for those added lights in the back?
I wired mine to the overhead light so when the doors open it is bright. I fished the wire to the left side area where the cargo shelf is mounted.
Thank you, I spent a few hours researching and finally found the right page with info... lol
Please add the link here in case someone else is on the hunt. It has been well established our search function is IA like in its use.
If you ease the rear light out of the roof lining you see it come with a reasonable amount of wire connected, unlike the under bonnet connectors or anything else Ineos left us to connect to.
I pieced in a short loom with a take off for the supply to additional lights, if the are low amps it should be fine, the fused circuit for that light is on is 5amp so avoid halogen's!
The connectors and bits I used are here
G.
