Rear cargo light
beg
8:42 AM
Scotland
I'm looking for a light solution for cargo area as I've fitted a cargo shelf and now need a light to fit underneath it just wondering what others have done to fix this . Also does anyone have a link for the overhead panel 3d signs . Cheers
Just noticed this.
I fitted a couple of number plate LED's via the internal light in the boot area, I patched into it with a new piece in loom and ran a cable out too the plastic cover over the top door locks. Reasonable simple, the biggest hassle was making the loom up with the itsy bitsy electrical connectors. not easy for big paws to play with.
I put some info here
G.
Check out Kingpin I mounted three in the cargo area, one above each side window and one on the rear door to light the table work surface. Used INT2 for power and added their dimmer switch.
This is what I went with. Not sure if I posted it previously but I mounted a long one on my cargo shelf and spliced the wiring to the light in the ceiling.
I can post some photos of my setup when I’m back in town, wiring was pretty straightforward and I hooked just the two on the windows to a dimmer switch since they’re a little tough to reach with cargo area full.
Thank you. I actually bought that extra switch from Kingpin but I never installed it. Vehicle wiring scares me more than house wiring. I actually had a parasitic draw on my battery because the wires for my Suma mirrors found there way to connect to each other behind mirror and caused my battery to drain. Good thing I am not a vasectomy doctor. :)
I put the shelf in mine from KAON, and immediately found the roof light was compromised. I bought one of these, and the pocket clip means it hangs in the middle under the shelf, and I can move it if need be. Very easy solutions. I couldn't be bothered with the wiring. I only use it occasionally, and I can move it around when I need it elsewhere. Very happy with it.
If you add the Kaon side molle panels you can mount two Stedi rock lights and run them off the roof light connection.
