Rear cargo light
beg
4:45 PM
Scotland
I'm looking for a light solution for cargo area as I've fitted a cargo shelf and now need a light to fit underneath it just wondering what others have done to fix this . Also does anyone have a link for the overhead panel 3d signs . Cheers
Just noticed this.
I fitted a couple of number plate LED's via the internal light in the boot area, I patched into it with a new piece in loom and ran a cable out too the plastic cover over the top door locks. Reasonable simple, the biggest hassle was making the loom up with the itsy bitsy electrical connectors. not easy for big paws to play with.
I put some info here
G.
Check out Kingpin I mounted three in the cargo area, one above each side window and one on the rear door to light the table work surface. Used INT2 for power and added their dimmer switch.
This is what I went with. Not sure if I posted it previously but I mounted a long one on my cargo shelf and spliced the wiring to the light in the ceiling.
