I love that guyI know a guy who is a friend of another guy who added the TDI box. He tells me it works for him, same experience as rob88 described. He said it no longer feels like he pushing the car to stay at highway speeds, he says it passes with confidence now. He is a good guy, I can vouch for him.
I had 2 bad experiences with the IO Box Tuner. (~$1000.) Limp mode 2X. It resides in a zip lock bag with the defective harness in my garage.) I gave up on theWe are finally about ready to buy our first Grenadier.
Can any of you who have REAL WORLD experience of chip tuners etc please give some honest feedback & thoughts.?
Thanks.
trucranemotorsports.com
If you go to the dealer you must remove any tuner, all of them or you will get caught and your engine warranty will be voided. That's a fact.
Burning rubber is the honest truth. I also have on my car set to extreme is the IO-Box Pedal Tuner, from Agile Off Road. Its a hair trigger. You can adjust through your cell or a disc fob. This is a really good system. I saw a video where they said it was quite easy to retune the Grenadier B58 to a much higher HP, without any add ons to the engine. This is interesting.Also Bluesurf said "At a light I accidentally burned 4 tire rubber." Are you sure? I couldn't do that even if I were in the middle of grass fire.
agileoffroad.com
15.7mpg according to the infotainment ? Or hand calculated ?I've had the TDI tuner for the past year. Did just over 9000 miles with it on going from the east coast and visiting most of the national parks out west along with a lot of off road trails. Left in mode 4 for all of it. Averaged 15.7 mpg with 4 passengers and 600lbs of gear. With the tuner it's a night and day difference. Acceleration and highway speeds no longer felt like driving a sluggish brick.
What was install process and where does it mount?I had 2 bad experiences with the IO Box Tuner. (~$1000.) Limp mode 2X. It resides in a zip lock bag with the defective harness in my garage.) I gave up on the
IO-Box and added the DINAN (one of the oldest companies in Germany, they back up the warranty). They have been making tuner stuff for decades for BMW. It's a fraction of the cost and I love the power. The quickest install too. If you go to the dealer you must remove any tuner, all of them or you will get caught and your engine warranty will be voided. That's a fact. Once it is removed it is not seen and there is no way for them to know. I delt will all of this with the dealer several times. This is the tuner I'm using for under $300.00 its awesome. My Grenadier drove like a brick, now it feels like a rocket. At a light I accidentally burned 4 tire rubber.
DINANTRONICS Sport Performance Tuner for BMW/Toyota B46/B48 and B58 En
DINANTRONICS Sport Performance Tuner for BMW/Toyota B46/B48 and B58 Engines DINANTRONICS Sport Maximum Gains (B58): Up to 40 HP, 50 lb-ft of torque. DINANTRONICS Sport Maximum Gains (B46/B48): Up to 25 HP, 50 lb-ft of torque. DINANTRONICS Sport is the boost controller for the masses. Its...trucranemotorsports.com
You have to be carful removing the sensors, you have to push on the release tab. This website will not me to upload a 14.1mb install file?What was install process and where does it mount?
Hand calculated. Tracked on an excel sheet every time I fueled up from the start of the trip to the end. Gallons Used, Price, and Mileage at the time. Tire pressures on highway were 42 Front/ 48 rear. Trails TP varied depending on environment. Stock 18in steelies w/KO2s. This is with a roofrack and crap on the roof as shown.15.7mpg according to the infotainment ? Or hand calculated ?
What mode was this on?Hand calculated. Tracked on an excel sheet every time I fueled up from the start of the trip to the end. Gallons Used, Price, and Mileage at the time. Tire pressures on highway were 42 Front/ 48 rear. Trails TP varied depending on environment. Stock 18in steelies w/KO2s. This is with a roofrack and crap on the roof.
It was left in mode 4What mode was this on?
