Quartermaster Deutsch plugs
Brock63
4:22 PM
South Carolina , USA
Does the QM still have Deutsch plugs for the rear set even with the bed verse wagon setup? I noticed the panel still has all of the EXT switches...so wondering did they put two plugs in each area externally since only the two front covers and load bearing handles are present.......or put the wires terminated behind the seat somewhere for access....or in the bed area somewhere.
Looked but couldnt find an answer as to if those switches are still LIVE and where the wires are run for use if still active.
On the AU spec the Deutsch plugs are only on the TWO rooftop power outlets, in the QM.
I am not aware anyone has found wiring for more than two.
On the IG one switch is for one rooftop power outlet and the second switch is for the remaining three rooftop power outlets. Each circuit rated at 25 amps.
I am only guessing, but the QM probably has one switch for each rooftop power outlet.
@Mudnut will know.
I am only guessing, but the QM probably has one switch for each rooftop outlet.
Thanks...yeah, I likely was not clear....wondering if they still gave us the wire leads for the other two connection points on Grenadier wagon somewhere else behind seat or in bed panel. Sounds like not.... Appreciate the answer and was what I thought. If I put a cage type setup on rear guess will just have to make some extensions to any lights I want in back mounted on it was work lights or otherwise. Thanks again.
They did not. If you think about it the wagon only had two switches that controlled two plugs. But one of the plugs has the other two Deutsch plugs. In the QM you have a right and left plug.
yeah, I recall that only two switches but wasnt sure if were going to terminate the other two plug leads somewhere else for use...of if they just snipped that portion of harness off. LOL
