Procedure to shift into Neutral with a dead battery (fiddly but doable)
holdmybeer
12:33 AM
Vancouver, BC, Canada
If your battery is dead and you need Neutral for a tow or a roll or whatever, sounds like a 5mm hex socket and access underneath the truck is required. With the Grenadier's clearance (compared to any other ZF vehicle), hopefully this doesn't mean jacking it up.
It's such a common transmission that details are around the internet, but here's one article: How To Put The ZF 8-Speed In Neutral Using The Neutral Safety Switch Bypass
As @Michael H. stated, on the Grenadier you use a 13mm wrench not the hex socket as on the traditional ZF 8HP... The wrench is included in the factory tool kit and has a substantial offset on the wrench to reach the required bolt. If memory serves me correctly, it is actually on the transfer case, to place it in neutral
Also, you can easily reach it without lifting the vehicle
And while you're under there, replace that plastic tranny pan with something more robust.
I did this with my Land Rover D3, hopefully there will be this option for the Grenadier as well. Will definitely do this when one becomes available
Thanks for that @anand. ✅
I hadn’t realised that the spanner (wrench) was in the factory tool kit, and I just put a 13mm socket and ratchet driver in my tool kit. 🙂
#Multiple cultures separated by a common language:
Translation: wrench = spanner
" you canna hand a man a granda spanner than a Sidchrome that's the brand the experts choose... "":ROFLMAO::ROFLMAO::ROFLMAO:
So in Australian that'd be a spanny, right? 🤣
A Shifter a shammer and a Leatherman will get even the biggest machines going again.
While I would, like you, also feel better with something made of metal, I have to say that the ZF oil pan is recessed so far up that there is little risk of damaging it. If you come over an obstacle with the front axle, I can't imagine how the pan can still be in the danger zone.
Would a metal cover dissipate heat any better?
It would, however, I'm not sure that these vehicles truly need it. Of course, someone monitoring trans temps while doing a low speed Summer desert crossing would be more appropriate to monitor the temps and report back
I don’t disagree it is not that vulnerable, but the other benefit is the replacable filter. ZF used to, probably still do cliam these are sealed for life. However smart owners will do a flush and replace of the fluid at 50-70,000 km and that is the time to replace the pan (you would have to replace even with the plastic one if you want to change the filter as it is built into the olastoc pan, which then means future fluid changes just need the filter changed not the whole pan.
Definitely never has and still doesn't. It's the car manufacturers which claim this. Changing the oil in a ZF auto is a critical task as it's a complicated procedure which has to be followed meticulously. Nobody wants to take over responsibility if something goes wrong. That's why the car manufacturers claim they have a lifetime oil fill.
ZF has always published maintenance intervals for their gearboxes like you have written: around 70K to 100K Km depending on the type.
The oil filter is integrated in the original oil pan. But the costs are moderate in face of the long maintenance intervals. A complete set is on the free market below 250€, including the oil and all gaskets and seals. Only parts, work goes extra, of course.
addendum
I would like to reopen this discussion.
Our French forum member @Virginie had a week ago a problem and could not get her car towed.
https://www.theineosforum.com/threads/panne-démarrage-startup-failure.12415439/#post-1333272310
I thought it was only necessary to put the transfer case bolt in neutral like explained in the manual.
But she said a “special hook” was necessary to put “also” the ZF gearbox in neutral, and as her car didn’t respond electrically, she couldn’t put it in neutral.
So my question is, in case we need towing the car is it necessary to:
  • Put the transfer case in neutral as explained in the manual?
  • Also the ZF gearbox in neutral (not mentioned in the manual)?
  • Or both?
@holdmybeer did reference (first post of this thread) a video “How To Put The ZF 8-Speed In Neutral Using The Neutral Safety Switch Bypass”.
Fairly easy, but, not for the Grenadier, no such bolt, as shown in the video, but the lever is indeed visible:
To check if I had to push or pull the lever to put it in neutral, I started the car and did put the inside BMW shifter in neutral, and this was the position:
Therefore pulling the lever should do it!
Then, car motor off, I did put a hook in the lever and hung 5 kg weight on it, not enough to reach the position of the former picture, but yes, it moved.
In fact, I am worried: what if I have a dead battery or another electrical problem, car wash function will not work: can I get my car towed or not!
And – if indeed mandatory – what is the easiest way to pull that lever downward. I have already an idea, but not that easy. No I will NOT carry a chain and a weight of 20kg in my car for in case of!
J'aimerais relancer cette discussion.
Notre membre du forum français @Virginie a eu un problème il y a une semaine et n'a pas pu faire remorquer sa voiture.
Je pensais qu'il suffisait de mettre le boulon de la boîte de transfert au point mort comme expliqué dans le manuel.
Mais elle a expliqué qu'un « crochet spécial » était nécessaire pour mettre « aussi » la boîte de vitesses ZF au point mort, et comme sa voiture ne répondait pas électriquement, elle ne pouvait pas la mettre au point mort.
Ma question est donc la suivante : au cas où nous aurions besoin de remorquer la voiture, est-il nécessaire de :
  • Mettre la boite de transfert au point mort comme expliqué dans le manuel ?
  • Egalement la boîte de vitesses ZF au point mort (non mentionné dans le manuel) ?
  • Ou les deux?
@holdmybeer a fait référence (premier message de ce fil) à une vidéo « Comment mettre la ZF 8 vitesses au point mort à l'aide du contournement de l'interrupteur de sécurité neutre ».
Assez simple, mais, pas pour le Grenadier, pas de boulon de ce type, comme le montre la vidéo, mais le levier est bien visible :
Pour vérifier si je devais pousser ou tirer le levier pour le mettre au point mort, j'ai démarré la voiture et j'ai mis le levier de vitesses intérieur BMW au point mort, et voici la position :
Par conséquent, tirer sur le levier devrait suffire !
Ensuite, moteur de la voiture éteint, j'ai mis un crochet dans le levier et j'y ai accroché un poids de 5 kg, pas assez pour atteindre la position de la photo précédente, mais oui, il a bougé.
En fait, je m'inquiète : que se passe-t-il si j'ai une batterie à plat ou un autre problème électrique, la fonction de lavage de voiture ne fonctionnera pas : puis-je faire remorquer ma voiture ou non !
Et – si c’est effectivement obligatoire – quelle est la manière la plus simple de tirer ce levier vers le bas. J'ai déjà une idée, mais pas si simple. Non, je ne transporterai PAS de chaîne et un poids de 20 kg dans ma voiture au cas où !
Merci Jean 🙏
Très intéressés par les différentes solutions car c'est bien ce levier sur ces photos qui est très compliqué à manipuler et qui à obligé le dépanneur à déplacer la voiture avec des chariots …. ☹️
This is the translation of the post above (Google translate):
Thank you Jean 🙏
Very interested in the different solutions because it is this lever in these photos which is very complicated to handle and which forced the repairer to move the car with trolleys…. ☹️
