"POWERTRAIN ERROR" and truck is out of commission
holdmybeer
3:35 PM
Vancouver, BC, Canada
Hi. I haven't been on the forum for months. Having too much fun in the Grenadier, partly. But lately the truck has been ... misbehaving. Thought I'd share this latest event, in case it rings a bell with anyone else's situation.
Since the truck's first service at around 17,000 km, I've experience a handful of times when it feels/sounds like a diff may be locking when the truck is cold around the first few 90 degree turns. Tire chirp/skid. Likely the rear diff? Maybe centre or transfer case. It was reported and went back in for investigation but dealer couldn't replicate. Diff and fluid levels were checked, all okay apparently.
This happened 6 or 8 times. There was one incident, again around a corner shortly after starting up, when it didn't lock but a big CLUNK came from underneath, perhaps the rear end. Also reported.
Then, a couple of days ago when driving up a long uphill mountain highway, the truck started to shudder and vibrate, followed by "Drivetrain Error" and a total loss of power. I limped to the side and turned it off. Dealer immediately dispatched a tow truck but I needed to get off the non-existant shoulder on the mountain so I started it and left it in neutral and rolled down the hill. The motor was running very strangely and rough upon starting it. Anyways, it's at the dealer. Has been for a few days. One bit of info the service manager shared was that the rear diff fluid, changed only a few hundred km ago, was unusually dark but no metal bits.
Video attached.
I have a loaner and I'm not rushing them because I need this fixed once and fixed for good. I have no confidence in long excursions with my truck right now.
My dealer and the service manager have been fast to take the truck in immediately, and are great to communcate with, and fortunately I live very close to the dealer. But confident answers about WHAT/WHY haven't been forthcoming. That's partly why I'm sharing.
I'll let you know what comes of this incident.
Maybe also worth mentioning ... maybe unrelated to the "Drivetrain Error" but who knows...
  • I've had the (common-ish?) 3-2 and 2-1 downshift clunk, which I notice is not present on any of the loaner Grenadiers FWIW.
  • My truck gave me the "Low Oil" warning 3 times in less than 1,000 km leading up to its first service (topped up with a litre each time). Headscratcher for the dealer.
  • I have a f**k ton of electronic warnings about signal lights, marker lights, brake lights, and hazard light malfunctions, and several back-up camera failures that the dealer is working on. Those don't prevent me from driving so I can afford more patience with those than I can with anything related to motor or mechanicals.
Maybe I have a lemon. Maybe I'm a glutton for punishment. But I still want to like this truck and I hope it all gets resolved. Have a good one.
  • IMG_3597_1.mov
    15.5 MB
Video attached.
Not good news. Keep us posted on the findings.
Video attached.
I had exactly this 3 weeks ago:
I will look at Differential oil, as I have always changed that oil myself, less that 10 miles ago….
Same symptoms as you, I was able to get home, let it rest, but every time I accelerated, it coded and went into limp mode.
Never issued a hard code.
Finally, after scanning system and resetting the non existent codes, I accelerated at a moderate pace, and CEL went away….
Yeah, I want to love one too. I currently sorta lust after one, but so far stories like this have kept the logical side from considering it. Good Luck, curious to hear the outcome..
Video attached.
Weird electrical errors could be due to a bad earth - there is a report of a recall for this.
Could be diff lock(s) but I tend to suspect the transfer case.
Have you used the centre diff lock? Engages and disengages well?
Yes, I've used centre (& front & rear) lock a decent amount offroad. Centre goes in and out well AFAIK. Front/rear have always taken some time to lock/unlock. i.e. drive some s-curves, cross fingers, maybe do it again, etc. I've always been told this is normal.
Thanks for the suggestions. I'll be touching base with the dealer soon.
For the Grenadier it seems, but like so many of it's 'issues' it seems to be down to implementation. Watch some videos on Broncos with factory e-lockers, they click in and out pretty much instantaneously, and don't suffer from the operational ridiculousness Ineos seems to have built in..
It is an open question as to whether it is the physical operation of the lockers or the indicator lights that take a long to time to operate. In my experience the lockers seem to engage and disengage quickly but the indicator lights lag behind for what is a unreasonable period of time.
On narrow New England trails there is very little opportunity to make sharp enough turns for the Locker unlock sensors to detect enough wheel spin differential to confirm the unlock. So the system stays in 'confirming' state for too long even though the driver can feel locker status driving just a short distance. A problem if you lock, unlock and then need to lock again on the same trail segment (which is often!). A poor design choice.
A little update... service manager has confirmed (and I saw for myself) very fine metallic particles in the rear diff fluid, along with a slightly milky appearance (suggesting ... water or air or ?). This is very soon after the factory fluid gets dumped at first service and replaced with an entirely different spec of (thinner, apparently) fluid.
Anyways, whether the rear diff is mechanically at fault or whether something electrical upstream was trying to lock it (that would be bizarre but they don't want that to happen again with a new diff) ... the process to replace the diff under warranty is underway.
So far, evidence suggests the current failure is not motor-transmission-tcase-shaft related. So far.
A bit of an update for me. This happened to me AGAIN this last week on Tuesday. I was coming onto the highway from a downward on ramp, immediately followed by a short, very mild uphill, gain to the next overpass. As I was accelerating through the downshift for the uphill, the drivetrain error came back. I drove the rest of the way to work with the error. When I returned to the car at lunchtime, error was still present and every time I went over 3 mph the check engine light would come on give me the error, and when I decelerated, the light went out at a complete stop until I hit 3 mph. I did what I did the first time after playing around with it, I boosted quite hard off of a complete stop, and the error went away immediately. Hasn’t returned since. For me, it seems that if I boost quite heavily from a complete stop, the engine drivetrain error, resets itself. Maybe it has something to do with vacuum or a leak from the blow off or similar. But, I still need to check differential oil.
I have had the exact same symptom 3 times. Only when I'm turning right 90 degree in an intersection by my home. Maybe 1/4 mile from cold start. Only when very cold outside. Get the error straighten out accelerate, it sputters a bit but otherwise seema normal. 1/4 mile later the message is there but the car drives normally.
Park the car, get back from work and no error message. Dealer checked but found nothing. I had to replace axle seals due to leaks, since then I've not seen the error. I checked the diff oil when they changed seals and it looked normal. They topped up the diff oil after the change of seals
Since then I've driven a lot and no symptoms. Been in even colder weather. No idea what that was. I have had no other symptoms or electrical gremlins.
I already had my diff oil replaced once as part of service. 75w-90 fully synthetic
I'm considering changing my transfer case oil and diff oil early.
Quick update because a few of you have DM'd me about how things are going.
In short, not well. It has been a month since my "Powertrain error" left me with a nonfunctional Grenadier. Cause was suspected to be an intermittently locking rear diff when cold. Or not. Dealer apparently cannot replicate. Or maybe motor because it has burned several litres of oil recently and was stumbling at the time of this failure. Or not. That seems to have checked out okay also.
For now, I have a loaner. Obviously, all I want is my truck back with:
  1. the cause of such a serious problem completely understood, and
  2. the problem completely fixed
We're not even at #1 yet, it seems. If either #1 or #2 aren't done then I don't have confidence in this truck or INEOS.
This all started (intermittent rear end behaviour) after the truck's first service around 17,000 km. They changed the factory diff fluid then. They've changed it since, more than once, and in very few km driven, they see fine metallic particles in the diff fluid. I'm told this is not normal. The dealer tells me they have asked INEOS for warranty approval to start replacing parts (diff? rear axle assembly? unsure?), but INEOS has apparently refused.
Anyways, thanks for the support and listening. I'll understand more and share when I talk to management at the dealer tomorrow.
Adding a data point, as this just happened to me but under a completely different set of circumstances. I was picking up food at our fav Mexican joint and my wife went inside to nab the bags. It took them awhile so I relaxed in the car, in park, sitting idle for about 15 minutes. Car was warm from driving awhile to get to this place. The engine started making almost like a rhythmic surge noises whum-whum-whum-whum, I kind of ignored it and kept reading. Wife came out we started to go and then POWERTRAIN ERROR and loss of engine power in the parking lot. I put it in park, shut it down, restarted, no error and it drove home fine (just a couple miles). Maybe crankcase vent valve? Seems weird to have that go out at <4k miles, but this is a quirky truck.
