People are aware of it in Australia , they just don't want to pay the extra or believe sampling a small sump capacity is not worth while. Service departments really don't like or understand oil analysis as a diagnostic tool.Oil analysis seems to be a very NA thing. Just an observation from someone downunder.
Load it up with more medication and order more expensive tests like the GP does.And what do you do if your car blood test is a bit off? Avoid future bad habits and get more exercise? Or add green tea?![]()
Even as a stduent in the early 80s I never skimped on regular oil changes. And shorter intervals for harder usage periods.The lab isn't giving you normal values to compare your results to so I'd just follow their advice and change the oil more often.
When I worked for an OEM engine company we were doing similar tests early 2000s to extend oil change intervals for Australian conditions comparing road train, B double and single trailer prime movers. This is when companies started developing oil change intervals based on fuel burn and duty cycle. The standard was about 25000km intervals then we started to see 80000 to 100000km intervals for some applications.Many years ago I used to run a fleet of Mercedes trucks. The cost of oil analysis (£30) wasn't much considering the 50 or so litres of synthetic oil. I can remember one truck doing over 200,000 miles before analysis said it needed an oil change.
As @NQ94 says, a useful tool for identifying any mechanical issues long before any symptoms show.
