Power steering noise
Eric.S.
8:40 PM
Hello everyone;) I was finally able to pick up my grenadier yesterday🥳 Unfortunately, I noticed at home that my power steering makes a strange noise. I think it's not a normal noise, or? The filling level in the container was at maximum with the engine warm but switched off. The German instructions do not say exactly in which condition the oil should be checked. Does anyone have an idea? I tried to post a video but I always see the file is too big (7mb)
Thank you;)
But I think I know why they are ‘silent’ on fixing it. IF the units really are $3k, that would crush them. My guess is that they’ll make a change and never look back. I’m wiling to throw a$500 at the issue, but not $3k- if they eventually ever fix it.
It will be really interesting in 10 years to hear the story about what happened with the steering pump.
100%, this will be a board thread: avoid buying IG’s with serial #’s or year or part…
I am looking for when these squealing steering pump Ineos grenadiers are a sign that you’re an OG. You were in at the beginning.
“Oh, wow! That one is REALLY loud, it must be a ‘24!”
... The pump is vastly more complex than an old school e fine driven pump. That is why the pumps are so expensive. This does not fit the original spirit of the truck. But it was inevitably required to comply to regs where the engine shut off system was required. That way the pump could operate when the engine was off.
It's very stupid. I would be very happy to swap to an engine driven pump if someone developed one.
They (INEOS) have shifted the TCO onto the owners; that's their strategy.
The reason for this is that developing a motor-driven pump requires real engineers. Although such a pump is significantly more reliable ...
  • ... the pump must be designed so that it can be installed and replaced even with the engine installed in the car (and not just on the workbench).
  • It requires a mechanical connection with all the associated consequences, such as gears, a lubricated drive axle with bearings, and also sealing to the outside against oil leaks (like all components mounted on an engine), etc.
  • there must be nothing that mechanically obstructs the pump's installation and the routing of the hoses.
  • with an electric pump, you connect the hoses and a cable, and that's it, no matter where it's installed in the end: you can mount it anywhere there's enough space.
This saves money in development and, above all, requires less engineering. Any idiot can tack something like this somewhere in the engine bay and connect the electrical cables and hoses; no one has to think about the mechanical drive & connection, lubrication, installation, maintenance space etc ...
I really think it has to do with the auto off situation. While my 2016 f150 auto off feature actually works really well, but every once in a while in a situation that needs a sharp turn of the wheel while the engine is kicking back on, the steering stiffens up.
If this is so (which I can actually not comment) than the auto off is just another "we-know-better" thing which is in an ICE car sheer nonsense. ICE in general run best if NOT switched on and off all the time.
In aircrafts for example, people shy away from unnecessary engine switching on and off like the devil avoids holy water. But in cars, politicians say, it's no problem at all?
The wrong people, because they're completely clueless, are simply proposing and passing such laws.
But I'll stop here, because this obviously has a political dimension - and not everyone can handle that.
Maybe there is little incidental planned obsolescence on the manufacturing side?
Yes, I know that "planned" and "incidental" are mutually exclusive.
The real engineers would be constrained by regulations, particularly out of the EU to reduce emissions. Like the Ineos charging system the power steering system has been developed for less emissions with systems in standby, same as stop start and auto neutral in the transmission. Make the car more reliant on the battery to reduce engine loads is the modern mantra for power hungry systems in cars.
The BMW engine is primarily designed for a number of different passenger cars with rack and pinion steering with electric assist or hydraulic systems with less loads so Ineos was left to work with BMWs previous engineering on an engine that was never designed with accessory drives in mind, or to be fitted to a small truck and would be too costly to extensively redisgn and production sequence for a car with low production quantities.
The electric pump would be more expensive, heavier and complex than traditional systems with the software development, sensors, ic boards and chips, motors, heat mangement, heavy copper wiring, fuses.
Leave the stop start on so that the engine shuts off when you’re sitting still
It doesn't make much noise (maybe none?) if I am stopped, engine running, wheel straight ahead. But as soon as it gets the least bit of steering input it makes that miserable whine. I had a state safety inspection done today, and the guy, who had never seen an Ineos before, was concerned that something was wrong with my otherwise pristine 1000 mile vehicle.
Mine started today at just over 1000 miles. It would be very nice to get a hydraulic diagram of the steering system to diagnose this property. It sounds like the system is going over the relieve valve. Either that or a valve isn't completely seating but it doesn't seem to matter if you give right or left steering input and it starts. But I don't know if it's an open center or closed center system without a diagram so very hard to diagnose properly. Perhaps someone with service manuals access can research this?
Does anyone know if this has been addressed on the AMAs with the IG people? And I’m still surprised at all the after market gear for the IG, but no steering pump??? It seems that car manufacturers are going to electrical ones to simplify things, so you’d think that there would be some options out there. I think part of the problem is that installed, you are talking some serious cash….
I have an update. I parked my wagon on very level ground in order to check the fluid. I haven't driven since the noise started. My vehicle was in my old shop with poor lighting (other than to my shop 20 meters away for level ground). I used my phone for lighting. Under the LED light it was immediately apparent the steering reservoir had been leaking. Oddly enough under daylight I couldn't see this yesterday. I put a piece of masking tape on the level indicator to improve visual feed back and checked the level. It was slightly above min. I slowly filled the reservoir to exactly the full mark and checked as I went with fresh tape. I started the vehicle and after one extremely brief steering input the noise left. I have test drove it since and all good. Moral of the story. The reservoir may be not perfectly calibrated for the system and make sure you check on level ground and run at the top end of the stick.
The Ineos steering has been designed incorrectly, we all know that although Ineos would not admit.
Too much pressure caused by heat (difference in climates) and the steering reservoir too small. The leak is from the little pin hole in the cap (release valve) and is normal.
I have not tried draining out the whole fluid or changed to a different type of fluid which doesn’t expand as much from heat yet.
In normal circumstances, topping up cold fluid to max is correct. But not in this instance. You will find once it’s heated up. The noise gets louder and louder, steering gets more wholly, and lock to lock much harder especially in hot weather.
Believe me, keeping the steering fluid at (cold) & level with minimum is best. Lock to lock is much easier and less wandering & dead feel. It does reduce the noise but doesn’t completely eliminate it unless in colder weather.
This is my alternative solution to installing an aftermarket steering damper. Basically the whole system is under too much pressure/fluid and needs a bigger reservoir to accommodate.
