I have just finished reviewing the "Cockpit Fuse diagram in the Owner's Manual and also as included on a laminated sheet in the glovebox on delivery... purpose was to decide on which fuses to tap to install a dashcam.
When one compares the said diagrams with the fuse layout behind the flap under the steering wheel, the diagram is laterally inverted.... e.g. Fuses FC18 - FC23 are on the far right of the fuse box, not the far left.... Also, the fuse marked FC23 on the bottom left of the diagram is in fact on the top right hand side of the actual fuse box. all other marques for which I've had fuse diagrams take the trouble to match the layout diagram with what one sees when viewing the physical reality of the particular fuse box... I've yet to check the other fuse boxes against the diagrams
Deeply disappointing
Attached is an updated diagram of the Cockpit Electrical Centre fuse layout which (I hope) represents the physical reality.
EDIT: F13 "Emergency Call" is empty on the Australian spec I assume because that facility hasn't been included here
