Owl Vans Grenadier Steering Box Upgrade
I hope that is what he meant by saying that he hasn’t heard the whine in awhile. There are a lot of people who say their IGs done’ whine. I am interested, but anything with an electrical pump is going to ‘whine’, I just don’t want to be heard from a block away, or have to keep lying to people that my IG has a turbine powertrain…
Damn at close to $3k… I may as well trade it in for a new one, which I would confirm to not whine
I meant taking a southwest flight over to az. I recognize the distance...
I should have been clearer...
No, you're good. But yeah not sure it's worth the flight. I'd rather just buy the thing and go have it installed in Austin and see what it does. I won't fully trust a test drive in a test bed vehicle. No telling what else has changed or how it will really change my truck. At least not in terms of something like this. It's cheap enough to not fuss over if it's not 100% as advertised. Plus I do have a touch of confidence in Owl on this.
Your comment made me wonder - the ~1" of play in the steering wheel: is it a genuine artifact of the steering box, or a software setting to avoid power steering working at all times?
There are most certainly some goofy things going on with the pump. I have to be honest and admit I have little experience with these newer vehicles with electric power steering. I have never owned anything with electric steering except my wife's Rivian. But I can sure tell when the system on the Grenadier turns on and off. And it most certainly shuts down when you approach the factory steering stop. Who knows what it does while driving. I'd prefer it to be less powerful for sure. I have always hated over powered steering on road going vehicles. I love one finger steering on my crawlers, but not anything that goes on the highway.
I know a video will not do much justice to a product that you typically have to "feel," but hopefully you can get a sense of how easy the Greny becomes at freeway speeds with this new upgrade. I also didn't hear any pump noise, but I still want to get ours back and test more before I am definitive on that front. Keep in mind, this Grenadier also has a 4" lift, which never helps freeway stability 😁
Ok that’s cool. Did you guys adjust caster? I can’t remember if you left that at the factory angle.
I just had the caster added last week when they did an oil change and door button fix. To me, the whine is pretty loud, but you can really tell in a garage or even up against a wall. Don’t know if you have a standard IG to side-by-side it?
What-o-what are people going to complain about if you ‘fix’ the steering…
I never found the steering that troublesome. I one hand it outside of rough pavement- and that is why I had the caster added; on uneven pavement, at highway speeds, and braking hard, it was a handful- definitely two hands full. That is too much to put my 18yo daughter and X5 driving wife into and expect things to go well. The caster seems to help, this would make it so that my daughter might actually drive it.
Thanks for working on this.
Funny how the inside of the OWL test mule looks like my IG, I didn’t realize how much OWL gear I’ve thrown into it.
I have to say I would absolutely do that with my truck as it currently sits. My return to center is also exactly the same. I would expect there are some differences that are not as easy to relay in a driving video. I'm still certain this is a great upgrade to be fair.
Honestly though my biggest gripe is how squirmy my truck gets when letting off the throttle at high speeds or hitting the brakes hard. My truck likes to dance a lot. If this pump fixes that I am very much sold.
Who can install this in New jersey? Do you have anyone or a partnership with? Or do we have to ship trucks out to AZ? Thanks mike
This looks pretty amazing!
Ran across this Interesting thread about a fix for cruise control and ESC issues. It traces the problem to the axles not being in alignment/square and outlines a procedure using the rear eccentrics to adjust thrust angle to get things lined up? Not sure if this is a legit factory procedure based on how the documents look but interesting none the less.
Yep. I came back here to point @Dokatd to that post and procedure. It's what was in my mind when I mentioned thrust angle above.
Latest posts
