Open letter to Sir Jim and Lynne Calder at Ineos automotive
So in Australia the aftermarket are developing products with help from Ineos Australia.
We have lots of options and now even chassis extensions for the Quartermaster.
I can’t see why the US companies can’t be doing the same
Exactly
To quoite the OP main beef
'Own the Driveshaft Issue: Stop the silence. Release a technical bulletin acknowledging the vibration issues on lifted or heavily used rigs. If the OEM part is the weak link, collaborate with a driveshaft specialist to offer a "Heavy Duty" factory-approved replacement."
Australia has not yet solved this
Here is my driveshaft. Caught at the dealer when I asked them to look at it after seeing @Logsplitter ’s (I think) post about his non-lifted rig having the failure.
Not that I’m an engineer but it appears to me that the boot is the real issue as it tears first allowing debris to get in the joint and cause the failure. My vehicle was non-lifted with only surface road and highway miles on it. My guess is the boot material needs to revisited or made thicker/reinforced.
Thanks for sharing that, really useful to see one caught early on a stock vehicle.
The boot as the starting point makes sense; once contamination gets in, the joint doesn’t stand much of a chance.
Add that to the propshaft failure list thread.
How many miles do you have on it?
Hasn’t there been a promise from Lynn to establish a regular exchange between the forum and specialists from IA?
If I recall correctly, that was one of her own ideas. What happened to this?
Nothing again? Shame on you.
The initial engagement was high after “the letter,” the start of AMA and the first 2 podcasts. I agree it’s disappointing since then, but my GUESS is they have some important steps ahead and we’re just in the quiet period before announcements. Fusilier plans, ODB2 access, service network plan - just my guesses and/or delusional fantasies. Maybe @Stu_Barnes and @Krabby know something but are under “press embargo” non-disclosure restrictions. Let’s see where things go this year - other than WWIII I mean, which seems to be well on its way.
At the time I had just over 27k mikes…no issues after replacement and I’m around 88k now
Is the replacement boot any different than the original oem one ?
You’ve put on over 60k miles on the new one alone. How is that lasting significantly longer than the original?
She got asked hard questions she didn’t want to answer so she took her ball as ran home.
I love my Grenadier but the company’s total un willingness to address the front driveshaft will become a criminal issue when someone get injured because it failed at 80 mph. They know it’s a problem and have chosen to stick their head in the ground.
