Americas Oil Change Reset
You can clear the oil change reset with the Ancel BM700 can clear the engine oil light. This is one of its primary functions, as it is a diagnostic tool specifically designed for BMW, Mini, and Rolls-Royce vehicles.
The feature is typically found under the "Service Functions" or "CBS (Condition Based Service) Reset" menu within the scanner's software. After performing an oil change, you can use the BM700 to:
  • Reset the Oil Life Reminder: This turns off the oil service light and resets the vehicle's internal computer so it can begin calculating the next oil change interval based on driving conditions and time.
  • Clear Fault Codes: The tool can also read and clear any related fault codes that may have been stored in the vehicle's engine control unit (ECU). So, if you need a scanner for your BMW to reset the oil light, the Ancel BM700 is designed to perform that function. If you buy the Ancel BM700 do not get the "PRO" model. This Pro model will scan your Vin, our Vin is Ineos not BMW. With the Ancel BM700 you can quickly get into your vehicle's systems by following this cheat sheet. I love using this device.
  • BM700 Menu Path for Grenadier
    1. Main Menu → BMW
    2. Manual Select (skip Auto VIN)
    3. Passenger Car
    4. 3 Series
    5. 2021–2023
    6. G20/G21 (this is the BMW 3 Series platform closest to the Grenadier’s ECU layout)
    7. Select All Systems scan
  • Tips for connecting successfully:
OK, so this would be a breakthrough.
FYI the service reminder is not algorithmic in our case: it is based on calendar day, odometer and engine hour set points, whichever comes first.
    1. Main Menu → BMW
    3. Passenger Car
    4. 3 Series
    5. 2021–2023
This is indeed 'manna from heaven' if it has the extensive utility for the IG described for the G20 3-series BMW.
@Bluesurf have you experimented as yet with the Grenadier TPMS to determine whether it can be reset with the Ancel Bm700?
    1. Main Menu → BMW
    3. Passenger Car
    4. 3 Series
    5. 2021–2023
Do you have this or just going off product description? If the latter then I assume this is not a solution..
It’s a see it before I’ll believe it scenario… share a video of the BM700 actually being used on a Grenadier (note the vehicle production date and software version just in case that matters) and see if it really works then we’ll know if we have a good solution for the pesky service reminder.
Reality is Ineos will have to release their data to the OBDII market soon enough. Maybe not full diagnostics but certainly rudimentary stuff like service reminder resets and such. Otherwise at least us state side dwellers will have a class action option available.
Some pissed off lawyer who owns a grenadier should just keep their legal department working and charging overtime.. pretty soon their cost benefit analysis will come around..
Where is that Calder interview on these more substantive questions?
I seem to remember that @IslandFalconer tried with the BMW dealer software ISTA without success. I doubt a $50 scanner would do the job
