My Grenadier Eibach lift, 295 70 18’s, OEM wheels. Vision X light kit.
Shawnpalmer
8:18 PM
Lake Lanier, Georgia, USA
My Grenadier lifted on Eibach springs, factory wheels on BFG KO2 295 70 18’s.
Let's talk the vision x lights. I want to get a pair? Opinions?
Worth every penny. I bought the floods. They are 1.5x brighter than the OEM high beam lights. Super high quality.
I was going to ask about the multi-LED floods over the single LED spots, especially if you want light for distance (high beams)
That’s got a great stance. Looks even more like a Tonka toy. Which is what I call mine anyway.
Those lights do look great. I was impressed with the OEM set up so god knows what they are like when used in anger.
Love seeing peoples projects and it fires me up even more to do something
I love the looks. What impact on acceleration and fuel consumption?
I like the look and anything for a bit more ground clearance is good.
I still wish Ineos had made the wheel arches a tad bigger.
The bigger tires always look too big for the arches.
Are those tires the next size up?
We wired in a relay
I’ve just fitted the lights using original wiring loom and they switch on then go out after two seconds is this why you fitted a relay? I’m not to good with electrics have you any Indio pictures on where you fitted the relay? Did you use the relay from the supplied loom?
What looks to be a factory wheel arch to support 35” tyres was seen in the wild in Africa a while ago during prototype testing and an Ineos video on an extended trek in Southern Africa.
Post in thread 'Largest Functional Tire Without Mods'
https://www.theineosforum.com/threads/largest-functional-tire-without-mods.12371337/post-1333142763
