Multiple service warning resets required?
Psignore00
4:46 PM
Apollo Beach, FL, USA
I took my grenadier in for its oil change Thursday. I was only getting the warning for days from my last service as it was right at the 1 year mark and I’ve driven less than 12,000 miles, but now that I’m home I’m getting separate warnings for service required based on engine hours and mileage.
Does the tech need to reset all 3 (time since last service, engine running hours, and mileage) separately or all they associated with each other?
Does the tech need to reset all 3 (time since last service, engine running hours, and mileage) separately or all they associated with each other? View attachment 7907449View attachment 7907450
the lot should have been reset
Phone 📱 the dealer and see what comment he has, that may be a fault not a fail to reset if only the day count down has been reset.
It seems they didn't reset. The procedure is not easy, and sometimes fails. I was last Wednesday at my workshop, and it took them several attempts to reset it (I was watching the procedure). But finally they succeeded through a detour: instead of resetting they changed the service interval. Apparently you can change it to any value. Both warnings disappeared.
