General Move to 48-volt mild hybrids
11:46 AM
Interesting to read the interview with Lynn Calder in the June 2025 issue of Car magazine. “For now, the Grenadier and its Quartermaster pick-up variant come with the choice of petrol or diesel 3.0-litre six-cylinder BMW engines. In a couple of years, they will switch to 48-volt mild hybrids.”
It will be interesting to see if Ineos uses the ZF system for the 8HP transmission and what they will do for the battery system packaging. There are not many places other then the rear cargo area for the battery.
The QM has the whole space from where the muffler ends and the rear bumper. A good 12 inches of not more.
Yeah I suppose the benefit of a ladder chassis is a deep area under the floor where, presumably, battery banks could be located without intruding into cabin space
It’s going to make an already heavy car even heavier though - which will surely hurt the range and efficiency. And potentially load carrying capability to keep under plated GVM?
Besides the negativ side of the batteries weigh the fuel consumption should be less with the mild hybrid system. So the range probably will rise.
BMW have been using the mild hybrid for a while and its well pretty much on most petrol engines nowadays.
I wish Ineos had got the eco mode that BMW use with the same engine. Its fantastic. It removes as much friction as possible when you are coasting and significantly increases MPG.
Reactions: CRH
Assuming they will use the petrol variant there is all the space available that is used by Adblue system in the diesel.
I wish that Ineos had constructed the whole drive system with less friction within ... An Eco mode would be the cherry on the cake.
Do you mean part-time 4wd? Mitsubishi used to do a system that let you drive RWD high, 4wd high with CDL open, 4wd with CDL locked. Worked well.
In the case of BMW, the eco mode, which is only when that option is selected, removes engine/gear braking when coasting. So, the speed drop off on a level road is very slow and allows you to coast for long distances and on downhill stretches, retain or increase speed without using the accelerator. When I first used it, I was gobsmacked at how much friction was removed. It was just like taking the car out of gear and coasting with the engine off (but with controls still working).
With permanent 4WD, the friction is significant, and the reality is that most of the time 4WD isn't needed. So, it is hitting fuel efficiency. An eco mode that can be enabled for road driving would be desirable.
