Mounting MaxTrax
ddv
9:31 PM
Central Victoria, Australia
I thought I’d share the following info to provide another alternative to mounting MaxTrax on the Grenadier.
Ive used magnetic pin mounts. This method consists of using four magnets which include pins to attach to a pair of MaxTrax using the MaxTrax’s normal attachment holes.
Once inserted into the MaxTrax mounting holes these magnets then are then placed on suitable parts the Grenadier (either the roof or the rear side panels since these are the only larger area that are not aluminium).
These mounts are described in considerable detail by Owl Offroad and associated Youtube videos. These can be seen at
https://owlvans.com/products/magnet...ubeDescription&utm_content=YouTubeDescription
Owl Offroad can only supply to the US market. Otherwise the magnetic mounts can be obtained from the manufacturer at Tactic Vans in Switzerland. https://www.tacticvans.com/shop/p/max-trax-quick-release
I have installed this set up and it suits me very well. It provides an easy way of mounting MaxTrax if you do not want to go down the PackRack or Moelle panel pathway. They enable the easy removal of the MaxTrax and the attachment paraphernalia when not offroading.
They are very stable and I am confident that they will not come off unexpectedly. They do not seem to add to noise or whistling that some packRack set ups create. A further advantage is that they they are lighter than the main alternatives.
I think that they probably involve a bit more work to remove the MaxTrax when you need them but I don’t think this is a major problem.
Another thing to think about is that they have no locking arrangements to prevent theft of the maxtrax. However it would not be difficult to use some sort of flexible bike or ski lock to secure them to the Grenadier’s side rails
View attachment 7881136View attachment 7881137
Hi,
I’ve seen your setup using magnetic mounts for the Maxtrax on the roof, and it looks exactly like what I’m considering for my Grenadier (mounted at the front of the roof, ahead of the rack).
Since you’ve been running them for about a year, I’d really appreciate your feedback based on real use:
  • How have they held up over time?
  • Any issues at highway speeds (wind, vibration, movement)?
  • Have you ever experienced any shifting or risk of detachment?
  • Do you use any additional safety measures (straps, secondary fixing, etc.)?
  • Would you still recommend this setup after long-term use?
I’m especially interested in real-world reliability, as this position is quite exposed to airflow.
Thanks in advance — your experience would be very helpful before I decide how to mount mine.
Best regards
Hi,
Best regards
Hi Manual,
I'm really pleased with the magnetic mounts. They've held up well and I've had absolutely no movement of them while in use. I cannot detect anything issues while travelling. No whistling, wind noise or vibration. One of the big advantages is that I do not need roof racks and I can easily remove the max tracks when I don't need them on board.
I have no reservations in continuing to use them but you may wish to consider the following:
1. I think that access is not quite as easy than if stored on side racks on the Grenadier or even on some arrangement at the back. However, since I do not need to use them that often and I prefer to use the other places for other purposes I do not see this as a problem for me.
2. I have placed some PPF on the roof where the magnets mount. I did this to prevent any scratching in case dust got captured underneath the bracket.
3. Although I have not used any additional straps etc you may want to use something lockable for security from thieves. However I don't think that any additional straps are needed for safety reasons.
Hope this helps you make your decision
