Hi, I installed a Wolf Box and the picture is laterally reversed. Is it possible to fix that?
Thank you.
Thank you.
Thank you.
Thank You DaneJa - I will try and dig out the little booklet that came with it and see if it explains how to update the software.I've never seen that on mine. I downloaded and updated the software (via microSD card) the first time it powered up, so it could be a fix from that if you haven't updated.
Can you share you how did this? I am finding the rear camera through the back window is too darkI just mounted my rear camera under the third brake light rather than the inside rear door window. Super crisp and bright image on the Wolfbox screen.
