More Wolfbox questions
I just mounted my rear camera under the third brake light rather than the inside rear door window. Super crisp and bright image on the Wolfbox screen.
I had my local shop make this bracket and mount the front camera in the front grill. Great view for lining up rocks!
I am getting the Unavi surround system installed on my vehicle today in Tustin, CA! The car came with the Wolfbox 900 Pro already from the dealer (Mossy in San Diego). I'll be sure to report back on how it went.
This thing looks pretty cool. I assume it's what you're getting installed? Can't wait to hear the review.
I’d be interested in mounting here as well. Now that you’ve had it a bit, does it seem too low vs the middle horizontal piece on the grill?
I'm gonna stop by today and check out the progress. The guy there showed me all of the components and how they mount. They replace the factory rear camera with their own using the same hole, and the other three cameras look to be same model with different housings. The ones that attach to the bottom of the side mirrors actually have a whole bracket that surrounds the inside of that mirror. The brain itself goes behind the dash, and its activated by the CAN bus - so automatically when in reverse, or by pressing the "OK" button on the steering wheel.
OK - I stopped by and took some progress pics. This is after just a few hours.
This is a pic of the replacement for the rear camera.
This is one of the side cameras with a new ring around the mirror frame.
Jimmy the installer showing me where the bracket will go for the front camera, with the camera staged right above while he gets the bracket in place..
Another view of that side camera.
All of this looks factory-installed. I'm pretty happy with how it all looks. I'll report back with a video of it in action, since I'm picking it up tomorrow after it's all calibrated.
This looks like promising tech.
Are extended towing mirrors much of a thing in the US? Either the clip-on, strap-on 🤭, or Clearview replacement types? That will be an issue with those clip on side cameras.
Rumour has it that Clearview in Australia are SLOWLY taking interest in doing replacement mirrors for the Grenadier. I'm waiting on a response from the local Snap and Zap importer to see if Wrangler or Gladiator clip on mirrors might fit the Grenadier. From a squinty distance the Jeep housings look similar to Grenadier but I haven't been able to compare them directly.
Is it possible to not have the giant padlock show up in the middle of the screen when a file is locked?
Does anyone know how you can permanently stop the irritating "connect to wifi" box appearing in the middle of the Wolfbox screen?
It tends to disappear after a few minutes of its own accord but always appears at a time that you actually want to see what is happening in the rear view camera?
I am not sure what benefit accrues from connecting it to wifi but I just want to see the current situation on the in car screen not record it on my phone or whatever wifi is supposed to do.
Eventually getting around to fitting my Wolfbox . I went for the hardwire kit so will obviously be using that.
I know there has been plenty of discussion regarding the fitting of Wolfbox's so I'm hoping to benefit from the experiences of those who have already installed theirs.
A couple of questions to start with though please?
Rear camera will go in the top of the right door but where is the best route to run the cable out of the door and into the vehicle?
When running the cable inside the car is it best run along the roof line behind and then into the roof console?
Best mounting place for GPS?
Any pictures or constructive advice will be useful.
Thanks
Pit the camera inside the door. When it rains you can use your wiper to clear the view. I did mine myself 6 months ago and it works brilliantly
I’ve never seen the connect to WiFi box you describe. Maybe have it turned off?
Sorry - I was working from memory - irritating message that pops up is "link Information to your phone" and then additional text on Wifi name and Wifi password as in the photo below.
Just wondered if there was anyway easy to stop it popping up and blocking the rear view screen at inopportune moments,
I've never seen that on mine. I downloaded and updated the software (via microSD card) the first time it powered up, so it could be a fix from that if you haven't updated.
I’ve never seen that message either.
