Lost bolt
Sauerländer
11:37 PM
Selm/Germany
Today I was in my hunting ground and shiftet a couple of times from high to low range.
Suddenly the little ring to delock the lever went loose and I couldn't shift the transfer case.
I found out, a little bolt supposed to stick in the ring to connect it to the shaft that lifts up with the ring was missing.
I took a little nail in sticked it from the backside in a hole in the ring.
Now it works again.
Will have to contact the service soon.
Is this a known issue?
Regards sauerländer
Now it works again.
Regards sauerländer
The retaining pin had fallen out. Known issue reported elsewhere here. Some folk have inserted a drill bit of the correct size then wrapped it with tape to retain it.
I have the same problem. Can not change to low. I found the pin in the car and the hole in the ring. But I can‘t stick the pin inside. Is there a special trick to do?
Dealer replaced the entire shifting mechanism when it happened to mine.
Today I went to a repair shop in Sofia (Bulgaria). They were able to insert the pin and secure it with adhesive tape. Back in Austria, the gear lever will need to be replaced.
can someone take a pic to show where the pin is at? and how you use velcro or zip tie for it? I have a hard time visualizing it.
Pics here...
