Lost bolt
Sauerländer
5:42 AM
Selm/Germany
Today I was in my hunting ground and shiftet a couple of times from high to low range.
Suddenly the little ring to delock the lever went loose and I couldn't shift the transfer case.
I found out, a little bolt supposed to stick in the ring to connect it to the shaft that lifts up with the ring was missing.
I took a little nail in sticked it from the backside in a hole in the ring.
Now it works again.
Will have to contact the service soon.
Is this a known issue?
Regards sauerländer
Now it works again.
Regards sauerländer
The retaining pin had fallen out. Known issue reported elsewhere here. Some folk have inserted a drill bit of the correct size then wrapped it with tape to retain it.
I have the same problem. Can not change to low. I found the pin in the car and the hole in the ring. But I can‘t stick the pin inside. Is there a special trick to do?
Dealer replaced the entire shifting mechanism when it happened to mine.
can someone take a pic to show where the pin is at? and how you use velcro or zip tie for it? I have a hard time visualizing it.
Pics here...
