Looking for REAL OBD2 / CAN Bus Experts
12:11 AM
Bamberg
Hi everyone,
I’m looking to connect with people who have serious, hands-on expertise in working with the OBD2/OBDII port and CAN bus systems on the Grenadier.
To be clear — I’m not looking for guesses, assumptions, or general advice. I’m specifically interested in individuals who actively work at a technical level with these systems.
I’ve just started exploring the OBD2 port of the vehicle today, and within about two hours I was already able to establish communication with four different ECUs via the standard CAN bus through the OBD2 port.
This was done without any deep reverse engineering so far — that’s something I plan to dive into next.
So there’s clearly more potential here, and I’d be very interested in exchanging knowledge with others who are operating at a similar level.
If you have real experience in this area and are open to discussing or collaborating, feel free to reach out via PM and name at least three Grenadier ECU's with their CAN bus IDs via PM - then we can talk. ;)
Best regards,
Dieter
Have a look am my post, the Swiss guys have got a long way, maybe they are worth contacting, they seem a small enough company they might be willing to help. Anyway have a look, if I can help please let me know.
https://www.theineosforum.com/threa...tool-globeguard-ch-obd-ii-must-read.12421461/
The ECU identification pages might be some help (I hope)
There is also another person sheel who is also looking at the obd
See
https://www.theineosforum.com/threa...some-intimate-time-with-the-can-bus.12420832/
See
Thanks, I've already seen those posts. But there a no new details to find there. I know of the device from GlobeGuard, but this can't do all of the features I'm looking for. They are using a more generic approach aas their device is on the market for some time and support a lot of other manufacturers.
Update:
I can now fully read the details from 4 ECU's over the ODB2 port. These four ECU's are easily accessible as they are responding on CAN bus broadcast request.
And in the meantime, I've also discovered and identified additional 14 ECU's, some are locked and some not. I can read at least partial data from them already, like VIN number, software and hardware model names, manufacturer and production dates of the ECU's.
So, in total I have basic access to 18 ECU's now (MY2023, Diesel) - not bad after just 24 hours of digging into that thing...
Brilliant, well if you can crack the service reset that would be amazong
+ default start stop to off!
+ default ac to recirculate
Are you planning on releasing some sort of software if you crack it? For a reasonable price 🤞😃 I’m sure you would have quite a few customers form this forum.
Good luck - if you want a beta tester let me know, willing to buy Hardware and test 4 u
Let's see how this whole thing is evolving. First, I want to see what's possible even without any cracking or reverse engineering. I'm currently just reading data from the CAN bus and sending standard requests to all the different ECU's on the CAN bus and see how much data I can read back. For later on, I do have some more crazy ideas... stay tuned :sneaky:
Just as a little teaser, here are a few of the live data what I'm already able to capture via the OBD2 port. Engine was running but car was not moving.
It's from a MY2023 Diesel produced in July'23.
1. Gateway Module
2. Engine Control Module
3. Transmission Control Module
...this is just the beginning... :ROFLMAO:
I'm really interested now, what hardware are you using? And software? Do you have to manually write it or ia a development kit provided with the hardware you are using.
I used to do a lot of rs232 /485 programming and control (interfaces and playback video systems for most large London museums in early 2000'a) so would love to learn more about OBD systems.
I used to do a lot of rs232 programming and control (interfaces and playback video systems for most large London museums in early 2000'a) so would love to learn more about OBD systems.
I'm just using some standard CAN-Bus hardware and all coding is done in Python for now. This way it's easier for prototyping, easy to change and fast turn around cycles.
One hardware I have is an OBD2 pigtail cable and a DSD TECH SH-C31G USB-to-CAN adapter, all from Amazon. This is the cheap low cost variant (50 Euro), but you have to assemble everything.
And my other preferred solution is a turnkey adapter USB-to-OBD2, it's more a professional automotive grade device, a pretty expensive Kvaser Leaf v3 OBD-II (350 Euro).
The hardware is just a small part, most of the work is to craft the software...
And I'm using a dedicated Linux device in the vehicle to do all tests live even while driving the car. A NVIDIA Jetson Orin Nano development board.
But here the major work was to get the Linux kernel drivers for the above OBD2 CAN interfaces running...
Update:
I've done now a first version of an OBD2 diagnosis program for the INEOS Grenadier ready which is working on my hardware.
I'm able to detect and access the first ECUs in my MY2023 Grenadier Diesel, I expect additional ECUs in later models - will test this as soon as I have access to other Grenadiers.
At least I can scan those ECUs for some generic data, like ECU name, mfg dates, serial numbers and also HW/SW versions installed (I have even more details, not shown in the report).
The most important part here is the number of fault codes (DTCs) per ECU, some have a really high number of DTCs stored.
Have to discuss the DTCs with my INEOS mechanic if this is correct and if I should have any concerns.
Currently, I'm analyzing the ECU data in read-only mode - all over the OBD2 port.
Shown details may be wrongly named or mis-interpreted, but I think you'll get the idea!
Update:
Good job my friend we are all with you . Keep up the good work . Looking forward to what you uncover !
So I have gone down a rabbit hole and got onto ecu remapping - interesting video below shows what he did, including bricking it.
Worth a watch, don’t think I will go down this route though, ;)
View: https://m.youtube.com/watch?v=DukVU860FjU
Right, but this is way too much.
My goal is it just to read the fault codes from all of the ECU's and being able to clear them - then I'm feeling better on a remote trip, even through Africa.
And I want to program my own TPMS sensor IDs (when rotating tyres), resetting the service interval and a few other standard maintenance tasks - very important when I'm traveling really remote with no chance to drive into an INEOS workshop!
I already had a closer look to the swiss OBD2 device, reading all their public product infos. I'm really not confident about their solution, all their infos on the website are purely generic and just a copy from other cars features they provide. Not a single Grenadier specific feature is mentioned, just fault code read&clear (which is extremely easy to implement). For them, I think, the Grenadier is an extreme niche product and they're more building/selling devices for workshops, not sure how they will serve end customers.
So, I decided I'm doing my own thing now. Makes more fun and I have it under full control.
I'd be interested if you come across anything about hidden settings, IE: Fuel Bong Volume, Auto Start and Stop default state, Aux lights allowed to be enabled w.o offroad mode for the americas, number of volume steps etc.
I agree that I'm not interested in going even 10% as deep as that video, but would be great to be able to set some of these a-la bimmercode for the Grenadier. Have you come across anything like this so far in your investigating?
Update:
Let me share a few details I was able to discover with OBD2, CAN bus and how this all works in the Grenadier.
1. I can access and read almost all of the ECU's of the Grenadier through the OBD2 interface over standard CAN bus
2. I can read all the fault codes of the ECU's and I can also clear those fault codes - I've successfully done that now! - no need for an expensive OBD2 tool (not for me)
3. changing or modifying any settings in an ECU of the Grenadier IS NOT POSSIBLE AT ALL TODAY - only the Bosch Grade-X (original INEOS workshop diagnosis system) has SecurityAccess to the ECU's in the Grenadier
At least this is my current status quo, today !!!
Currently, there are almost zero OBD2 tools on the market which are able to clear the fault codes of all ECU's in the Grenadier (I personally know just of a single product, but it's not verified, not by myself).
And I honestly doubt based on my recent research that there will be any solutions on the market soon, which could get write access to the ECU's !!! - But, proof me wrong!
And here the positive results from today - clearing fault codes works !
Step 1: read all the fault codes
Step 2: clearing all fault codes
Here, one fault code (DTC) was not cleared, but I run the clearing process a second time and then it was gone!
Step 3: verify remaining fault codes after clearing them
Success - all ECU's fault codes are cleared !
Update:
2. I also can read all the fault codes of the ECU's and I can also clear those fault codes - I've successfully done that now! - no need for an expensive OBD2 tool (not for me)
Step 2: verify remaining fault codes after clearing them
I assume you faked a fault on your DDE module to test a clear? I'm not familiar with DDE since we don't get that option in the US but the DME I would assume has very similar fault code mapping. When I watch the techs access the DME here in the shop they must connect the BOSCH controller between laptop and OB2 and then request a two factor auth code from Ineos 3rd party team that writes their software. But that access level was only needed to clear hard faults or the faults that show up RED that cannot be cleared without that access level. How deep can you see into your DDE right now? For instance if you are able to write to it, you could clear hard faults.
As I said above. Clearing normal fault codes is possible, I've wrote a program so I can do it all the time by myself. I didn't faked anything, these were active DTCs and I was able to clear them!
I would assume, this way I can't clear hard faults.
For write access to the ECU's and of course the DDE/DME as well, you'll need SecurityAccess - this is only possible via the Bosch Grade-X !!!
